redstrosekNic's Avatar
Torque Wrench Question
Hey guys,
I just bought a Precision Instruments split beam torque wrench. It seems like a decent tool, but there is play between the body of the wrench and the ratchet head. Is this normal? I've never had a split beam before, and have nothing to compare it to.
Dustin
Old 09-20-2013, 01:47 PM
I'm with Bill
Rick V's Avatar
Some play is normal especially at the lower settings. Some of the chain tire shops have torque wrench testers there to help stave off lawsuits from inept tire guys. I am sure they would click it for you to see if you are close
Old 09-20-2013, 01:52 PM
Thanks Rick. The play is consistent, regardless of the setting. I am thinking it is normal, as there is a split beam running through the center of the tool. I'm out to the garage to see if the split beam moves around, causing the need for some play. I admit I have no idea how this type of torque wrench works.
Dustin
Old 09-20-2013, 01:57 PM
Call the company.
Marv Evans
'69 911E
Old 09-20-2013, 02:14 PM
I sent them an email, but figured you guys would be less likely to say "it's fine... Blah blah blah".
Dustin
Old 09-20-2013, 02:38 PM
Bill is Dead.
cashflyer's Avatar
I buy only Precision Instruments. They are [one of] the best on the market.
A little bit of play where I have indicated is normal, and necessary for the split beams to function. If they were rigid, this would just be an expensive "breaker bar".
Old 09-20-2013, 02:53 PM
^^^Exactly what I was concerned with. Thanks for clearing it up for me
Dustin
Old 09-20-2013, 04:02 PM
