Targa, Panamera Turbo
Best Way to Clean Carpets That Have Paint Stains?
Painted my Sons room - used a latex. I thought I covered up well with drop clothes but I noticed some dried paint. Whats the best to use to clean it?
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
alcohol (not the drinking kind) will soften and remove latex paint with a treatments
Might just try water first, then denatured alcohol. Don't go too strong or you'll mess up the backing.
Now in 993 land ...
No wonder if you dropped your clothes. Next time use a drop cloth.
But seriously, I would just call a trusted carpet cleaner guy to fix it for you. A good deep clean every year on the carpet will not be a bad idea anyway. I hate carpets with a passion. What a great way to keep filth, smells and gunk present at all times. The worst thing is that they seem terribly popular in rental dwellings and you inherit the previous tenant's funk. When I have a choice it is wood or laminate floor with drop carpets where absolutely necessary. G |
Cars & Coffee Killer
Don't listen to these guys. It's very difficult to get dried paint out of a carpet without ruining it. It's much easier just to get a quart of paint matched to your carpet and paint over your mistake.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
I would try to carefully apply paint stripper in small amounts to exactly the paint spots. Paint stripper does not seem to bleach it just softens up dried paint. It can be cleaned up with plain water and neutralized with a little vinegar. And since it is kind of jelly like it will not go deeper than necessary into the carpet fabric.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
I'm a professional painter; What we do when that happens is scrape a bit of the carpet's top with a blade... there is really no other way, you'll ruin your carpet. You can slice across and poll with your fingers, the dried up paint should come off pretty easy. You can actually do this without damaging too much your carpet. If the paint is dry, there is no way you are gonna remove it with water and soap... maybe very hot water, I guess that could work, if you are reluctant about using a knife to your carpet.
Student of the obvious
Goof Off - actually lists dried latex paint as something it removes.
Lee |
the denatured alcohol worked great thanks?
D) None of the above.
. Home depot...you will not believe how well it dissolves latex. . Motsenbockers 22-oz. Latex-Based Paint Remover (Lift Off #5)-413-01 at The Home Depot .
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
canna change law physics
Vinegar works great as a latex remover. It will even loosen paint that has been on for years.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
This stuff has worked for me
