Chin Spolier - fast/easy/cheap/effective
Chin Spoiler - fast/easy/cheap/effective
Extra deep garden edging 6" deep x 20 foot long coil purchased at ACE Hardware for approx. $12.00. Secured straight up though the lip with a dozen Stainless Steel #8 Phillips screws 32 tread count, 1 inch long, lock nuts (nylon insert type) 9mm. I'll post the fuel savings later in the week. For the first 50 miles driven today I've gone though less than 1/8 of a tank, normal is a hair over 1/8 tank. At 70 mph the engine is turning at 2,050 rpm, I think that is about 200 rpm less than before. So it's like I'm driving 5 mph slower than actual speed on the highway, and that is bound to add up. Only a couple of hours to install. Photo Gallery http://s184.photobucket.com/albums/x295/kach22i/S10%204x4%20Pick%20Up/ ![]() I have enough material left over for two more trucks. ![]() Automotive plus fill the binding holes, first securing point is centered. ![]() ![]() Curb clearance is reduced from about 13 inches down to 7 or 8 inches, still double of my old Porsche 911 which has more of an overhang. I'm used to not pulling all the way up to a curb, don't do this modification if you are a curb knocker, or at least use a standard 4 inch PVC lawn edging in lieu of the deeper 6 inch one shown. ![]() ![]() Some air gets in through the tow hooks, I'm not going to block these off until I can test engine temp's in summer while towing. ![]() ![]() ![]() Compare it to my neighbor's stock S-10 4x4, from mid bumper down all that air gets compressed then sucked up under the vehicle by the vacuum/neg air pressure under the floor and tumbles around in drag causing vortexes.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Pre Registered
Nice! I like it.
It reminds me of the flex dams that were popular for 914's long ago. ![]() Tim |
You know, that doesn't look too bad, George.
I don't know how effective it is with the truck lifted but it might help a bit.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Yep, 7-1/2 inches of ground clearance is about double of most cars even ones which go though a Michigan winter. It's designed for some snow and those ruts which form in the snow from tires. The plastic lip of the original valance is a weak point, I could used metal straps and go up an extra 6 inches or so to secure to metal. However the new chin spoiler is flexible with a top loop which can compress with vertical loads. If impact loads occur they will be evenly distributed. It's an experiment, time will tell if it works out.
Interesting.
From an aero point of view (ignoring cooling and curbs), is there such a thing as too much air dam? Suppose I used your trick and extended the 911's air dam to 1/2" from the road? Would I get instability? |
Kantry Member
Neat idea! I've been tempted to do the same with the F-150.
Not sure why you are thinking you are getting a reduction in RPMs at speed since that would happen only if your torque converter (automatic tranny, right?) had been slipping or you were running larger tires. Any mpg increases whould come from reduced throttle openings due to lower horsepower requirements at lower drag levels. Keep up the good work! Les
Best Les My train of thought has been replaced by a bumper car. |
entertaining the idea
You know what? It looks a lot better than I expected when I began reading this thread. Keep us posted.
There are some who call me... 'Tim'. a well set-up 1983 Guards Red 944 |
Did you get the memo?
I'll give you credit George, that's not half bad looking. |
My 1976 Ford van spoiler I made back in 1983 was about 3-1/2" from the ground. It was still like moving a brick through the air, but was not being knocked around the road on windy days. The steering was really lose on it, so this was an important improvement.
EDIT: I have a fabric cover for the bed which I have not put on. I also have some metal straps and smoked acrylic. If all goes as planned, one day I will install a Gurney flap spolier which I can see through. This will be after the top half gets zebra stripes of course. ![]() http://www.ten-tenths.com/forum/showthread.php?t=111608
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 03-29-2009 at 11:24 AM.. |
Looks really great.
Actually that exact same stuff is used by miata folks to make airdamns. Yours looks better than most that I've seen.
Feelin' Solexy
My thoughts exactly.
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
2,050 at 70 mph 2,150 at 75 mph 2,300 at 80 mph Before the front chin spoiler was put in I think rpm's were up another 200, I'm looking to go from 18.5 mpg to 20 mpg. I just noticed the rpm's today because the radio seemed some much clearer and more detailed without the extra engine noise.
I don't know if that lip is enough to make a big enough difference in drag to make a 200 rpm difference at speed, but theoretically, it is possible.
Make Bruins Great Again
If you really want to boost the mpg's, remove the rear tailgate. Look at it like a giant parachute catching air and slowing you down as you drive.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
I'm with Bill
That splitter looks remarkably good.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Navin Johnson
http://www.gminsidenews.com/forums/f22/leave-tailgate-up-better-gas-mileage-11678/ Quote:
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Slumlord
I will be shocked if it makes a measurable fuel consumption difference.
Change all your fluids to full synthetic. Tranny, engine, and rear-end.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
I thought that and lots of other folks have thought that. The mythbusters even tested it and asked Ford Truck design engineers if they could explain it. Yes, they did explain it. IIRC, the air that goes over the top of the vehicle creates a clockwise swirling vortex in the bed. That vortex has a similar effect to making the truck a fastback. The air that isn't part of the vortex flows right over the back of the vehicle. They said that opening the tailgate actually reduces the effect and hurts the drag of the truck.
I found a this
