I took some pics of my current water heater.
![]() This is the current unit. It is in a little closet that has its own door. This is out in the garage. ![]() Obviously a 40 gallon tank. 35.5K BTU and we keep the temp on about 1/3 of the scale. It could get a LOT hotter. We don't run out of hot water. Now to find a local source for a AO Smith water heater. So far they all want to sell only to a plumber.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Just saying:
Our Rinnai started leaking when it was 3 years old. The exchanger was replaced under warranty. Trouble was that labour not covered - 700 bucks to install. |
I would be remiss to not suggest using a solar hot water system to pre-heat your feed water to the existing hot water heater. Full Disclosure - I'm in that business, however, there is nothing quite as nice as taking a hot shower knowing that you did not burn any fuel to make the water hot!!
Agree on the recirc pumps as well - fresh water is one of our most precious commodities, running it down the drain while waiting for the hot water to show up is pure waste. Happy to go into more details if anyone wants.... best td |
I forgot to add this: Not busting your chops here, but knowing is one thing, but at what cost. As far as recirc. pumps are concern, I advise against it at times (talking myself out of a job) because the financial benefit does not add up. I can't suggest tearing out walls, installation return pipes, running electrical then buttoning everything just to speed up the delivery of hot water. I wouldn't do that to people. They can wait another 30 seconds for that hot water. It not worth $1000 bucks of work. if they are doing a full remodel, then I would suggest it for sure. Last edited by look 171; 12-21-2013 at 10:35 PM.. |
I was in Lowes the other day and they had on display Jacuzzi brand tankless gas water heaters for $849.00. Just from reading the package they are designed as whole house. I thought that price was not too bad but have no idea about the quality.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Bandwidth AbUser
Jim R. |
A single pipe is very cheap to run (plan for the future) when everything is out during the remodel. This is not where you want to save money.
Because with that. A simple 20 gallon tank heater will run the whole house also, but most of us know better then that. Tankless heaters are size according to flow rate. count how many outlets (1.6GPM) and size the heater accordingly. I normally ovedr estimate that number a little more then most out there. Overbuilding is my middle name. People appreciate that in the long run.
Bandwidth AbUser
Jim R. |
"30 seconds to wait for hot water" may not sound like much, but when you are on a well, in a record low rainfall area, and you add up the amount of water that you are dumping into a septic system with no benefit, the 'economic savings' becomes secondary. As a simple measure, put a bucket under that '30 sec's of water' to get a feeling for how much it is....and then multiply by the number of times you do that per day and then by 365. I think the volume of wasted water will be staggering!
Record low rainfall area = all of CA in 2013. Running out of fresh water in either NorCal or SoCal may be a pretty big deal....for some. A recirc pump might make some sense in applications such as these.....as might 'grey water' diversion from the septic tank into the garden area. We are investigating both at this time for the above mentioned reasons. And we've installed Solar Hot Water for the pre-heat on the propane fired hot water heaters, reducing our propane consumption dramatically. In many areas with abundant water and 'free' natural gas, these sort of measures might not make 'economic' sense, even though it is probably the right thing to do. I don't think 'recirc' and 'tankless' are ever used effectively together....better to mount the tankless near where the water will be consumed. two cents worth of my opinions.....YMMV cheers for the holiday season!! td |
Around here the water is mostly from man made lakes and run-off water. It goes back to the sewer system and continues on down stream. I just interrupted it's flow after it was run through the water system and the sewer system. It did not get destroyed in a black hole. It just continued downstream to the Mississippi and out to the ocean. Several other cities will process that same water several times before the ocean evaporates it and it falls as rain to begin the cycle again.
Natural gas is cheap and we produce a lot of it locally. I am still trying to find what model of AO Smith water heater to get and a source to buy it. The local plumbing companies want to deal with a plumber.
The ideal situation would be to have two smaller instant-on water heaters in the house one in the kitchen and one located directly next to the shower bath area. This will keep your water /waste usage to a min.
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
I just want a reasonably efficient quality water that will not need to be replaced for 20 years or until the year 2034.
Depending on how the new pipes are run, hot water delivery may surprise you to the Kitchen. No one knows how the old pipes are snaked around under the slab. It could have been a much longer run under there. |
Bandwidth AbUser
Jim R. |
and it didn't work. Had to remove it drive back to HD and get another one. Installed the second one and a month and a half later it stopped working. Removed it and went to Lowe's and purchased a Whirlpool. So far so good. Also had very bad luck with A O Smith 50 gal. electric water heaters in my home. The first one leaked after 4 years 3 months. The second one lasted 3 years 2 months. The third one lasted 2 years 2 months and the forth one lasted exactly 1 year. All 4 of them leaked water. Junk!!!! The only reason I kept using AO Smith is because they were under warranty. When the forth one went bad the 9 year warranty had expired so I went to Lowe's and purchased a Whirlpool. A O Smith told me it was because I have a water softener. |
I went with this Triangle Tube Phase III Water Heater. Uses a zone off the boiler. It was not cheap, but it has worked well in the 10 years I've had it.
Indirect Fired Water Heaters | TriangleTube
Ed 1973.5 T |
