'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work. Malo periculosam, libertatem quam quietam servitutem. |
I'm sure it's a fine product when installed properly. And it sounds like this builder had plenty of experience unlike the Habitat contractor I spoke of. However as with any construction type problems may develop over time, which is why people do home inspections before (not after) they buy. Going negative for a moment, if this contractor had a history of using this foundation system despite any red flags (ie..unsuitable soil conditions) and going ahead because it was "their standard procedure" then there could be cause for concern. Someone in this thread previous said this wall system was more expensive than standard foundations. I do not know for sure, but doubt seriously this. The main attraction of using this type of basement wall is "construction time" and "energy efficiency". Longevity issues seem to demand a discount in my opinion, but I've never conducted an real estate assessment, so I'm talking out of my arse on that issue. I do not see a stated or even an implied life-span on this product. Superior Walls By Collier Foundation Systems, Inc. Maybe someone can chime in on this issue. If it's expected to last 50 years, and it's a 25 year old house, the value should be discounted or based on future replacement costs in my opinion. As a rule; stick build homes has a life expectancy of only 50 years, 75 with proper maintenance. Masonry construction 100 years which can be extended to 200 years (university buildings for instance). There will be many exceptions to these rules to be sure. These are just general guidelines. HVAC, Plumbing, Electrical and of course roofing materials all have limited life spans which may be shorter than the basic structure of the home. In the end, all we ever buy is time, the more time we buy the more expensive it is. Remember the story of the three little pigs and the big bad wolf which would huff and puff? You get the idea.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Platinum Member
Kach, they are slightly more expensive. However, they have built in insulation and are ready for finishing basements (no studs needed). Easier to meet new energy codes. I know a few local builders switching over, and have spoken to the local inspectors about them, they know of some 20+ years with no problems.
25+ YO Block foundations were not reinforced, and are much weaker and may need to be repointed. Poured walls have their own problems, especially if the contractor is not supervised.... Failure above was because directions were not followed, first floor deck framing needs to be done and basement slab poured before back-filling. Can't take shortcuts with drainage or stone. I have not switched and continue to use poured concrete mostly because of what I read here. Although I think superior walls have advantages, I think the average customer is less accepting of a new product like this. |
Thanks again everyone...looks like the deal is moving forward so I'll report back in 20 years and see if they are still holding up! Seriously though, I'm becoming quite comfortable with them the more i read and understand...I agree with dad911, I think it's not the easiest sell to a lot of people because your standard poured foundation seems so time tested and the "why change what works" attitude prevails. That said, I like to be different, so I'm hoping this foundation treats me well! Appreciate the feedback as always...
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2019 Tacoma |
The 9 Store
"Someone in this thread previous said this wall system was more expensive than standard foundations. I do not know for sure, but doubt seriously this. The main attraction of using this type of basement wall is "construction time" and "energy efficiency". "
The builder told me it cost him $1K more per house (y2k dollars) but felt all the selling points were worth it. Could be installed in any weather, could be built on immediately, sold with water proof warranty, could be finished at less cost, ect. |
1. I have been unable to find a projected life span for this product. 2. If the life span is 50 years for the "system", and 100 years for concrete and the age of the home is 25 years old, then is the concrete foundation home worth more because of future replacement costs? I don't know, just asking. 3. I have never used this product. 4. One important item being over looked is the energy use, if you save money long term on energy bills, then this savings should be part of your consideration. If I were you, just call up the foundation company and ask for a projected life-span. A fair amount of homes in my neighborhood have new basements put in, some because they are rentals with lower level apartments, some because of age and failure. My own basement has a layer of ThoroSeal on the inside (and outside) trying to hold it together a little longer, nothing lasts forever. Based on what others have said in this thread, get the house inspected, if it checks out put an offer in. I just wish I knew what the expected life-span of this foundation system is, then I could spout off an enhanced value or depreciated value. As it stands threat it like you would any other home purchase (risk), and take your best guess. EDIT: I re-read Post #14 where I mentioned "a discount", that was meant to read "a discount should a problem be discovered", and not "a discount for undiscovered problems". It is not written so clearly, sorry. The overall concept of a value or discount based on maintenance and longevity is not exclusive to this foundation system, it applies to everything inside and outside the building and site. Old septic system systems and swimming pools are notorious for lowering the value of an otherwise good home.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 02-24-2014 at 07:40 AM.. |
Learning Curve
Learning Curve: Permanent Wood Foundations - The Inspector's Journal Forums Quote:
Permanent Wood Foundations by Nick Gromicko and Kenton Shepard http://www.nachi.org/permanent-wood-foundations.htm Quote:
http://www.nachi.org/forum/f23/pwf-permanent-powdered-wood-foundation-23709/ I don't know if the rod mentioned in the quote above is the same as the screwdriver method mentioned in the second link - sounds invasive to me if this is what they are doing. I was hoping they used a moisture meter like they do for boat hull inspections, something not poking holes in the membrane or panel skin. INSPECTING PERMANENT WOOD FOUNDATIONS November 30th, 2010 | 16 comments http://www.structuretech1.com/2010/11/wood-foundations/ Quote:
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 02-24-2014 at 08:05 AM.. |
I'll put my 20 cents worth in regarding wood and "inferior" wall systems.
Wood systems would be a no unless what your are putting on them is disposable. The current treatments for wood systems simply do not last. If you'd make them out of Cyprus I'd be willing to go for that. "Superior" wall systems have various flaws. Unless the stone foundations are well done the walls will move and crack. Well done means excavated and stone placed and tamped in lifts with no freeze thaw cycles while stone is placed. Then, concrete needs placed for floor prior to backfill ( never happens that way btw). As well, no treatment of foundation wall is done in that it's a 5000psi mix and "waterproof". Well with 2" of concrete that is poured,shipped prior to 28 day cure, and placed while curing I have no confidence in it not getting cracks and therefore leaks. As well, with insulation attached to the back side if you are in a high termite area you'll have no idea if you've got termite tubes under the insulation. If I was building a house and the gave me superior walls I'd use em for my garage but not my house. I'd go with 8" of well done concrete anyday. I inspect commercial construction for a living btw, w/10+ yrs inspecting and 30 years in construction. |
Around here we use 12" block or 10" pour.
I saw a 8" block basement once in my old neighborhood while it was being built by some Arabs. A couple of weeks later I went back to see the basement walls all caved in, no rebar, no web reinforcement, no solid fill in the corners, nothing. Any system can fail if done wrong.
Rarely if ever does any build basement foundation walls with masonry anymore. By the time you place bar/fill at 5' vertical max pours per lift it isn't worth it. 8" with bar concrete or 10" w/o vertical bar and you're done.
The folks who like Superior walls use them as a cheap way to build without pouring concrete. "IF" they were so awesome nobody would be using poured concrete the same as we no longer do masonry because of cost vs product |
dyount, do you see problems with SWF leaking, cracking and shifting when installed properly?
If..... the footing of stone is done properly by a competent contractor and the walls are placed correctly and the floor is poured then the floor above framed and then back filled they should be fine.
Problem is for the most part if the structure is backfilled and has insulation on the inside you don't know if it has a crack in it until the basement has a puddle in it. This time of year in PA you wouldn't have a clue other than water marks on the floor. Fact of the matter is depending upon who's doing the foundation work a poured concrete wall could fail just as easily. I inspected a rack of townhouses some years ago that used SWF's and the whole thing left a bad taste in my mouth. Frozen ground without blankets , no hard hats on the set crew,missing connection bolts,horrible caulking between panels,bad connections that didn't meet spacing requirements for attachment of panel to building. Then again I failed a footing 2 weeks ago because the builder had no blanket to cover what was to be poured. "It's below the frost line I don't have to protect it"..... Umm yeah dude it's 11 degrees now and below 0 by morning.... no you don't get to pour until I see blankets next to the ditch. I'd never have that conversation on a commercial jobsite. They'd be ready to pour,cover and also have a laser thermometer so I'd know exactly how warm it all was before pour (earth within 20 degrees of concrete temp) |
FWIW, this is a new (~2yr old) house and I know for a fact that the Superior walls were installed by a very competent outfit that has LOTS of experience with the product...floor was poured before backfill (pics to prove) and everything done per spec so I feel quite confident the installation is up to par....the question i suppose is to ultimate longevity versus a poured foundation. Guess I'll see...
