Remington shotgun question
Probably should have asked this before I'm sitting in a turkey blind.
Put a magazine plug into remmy 11-87. pulled plug out of a 870. Now it only accepts one shell. What did I miss ? Sent via Jedi mind trick.
poof! gone |
The second turkey?
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
if i had a nickle for everytime I heard that....
Jim '85 911 Carrera-#008 '23 GMC 2500 AT4 _________________ |
If you can, do a search for remington 1100/11-87 owners manual pdf file. On page 14-15 of the manual it gives a disassembly procedure for removing the plug. It's a little too long to post here.
fixed post
bunch of random cars and bikes. Last edited by Aragorn; 04-09-2014 at 09:30 AM.. |
This post has a guy with similar problems with his 11-87 being a single shot also.
Remington 11-87 problem - help! - The Firing Line Forums
bunch of random cars and bikes. |
Constitutional Liberal
But have you heard it from a female while you were awake?
It's your fantasy, you can make it as long as you like......
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Slackerous Maximus
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Double Trouble
tell me how how swapped them...
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
Haha. Well played. I thought the 1100, 11/87, 870 all used the same green plug? My 11/87 uses 3" shells. Maybe the 3" gun is diff. Dunno. Sent via Jedi mind trick.
poof! gone |
Double Trouble
they are the same plug. it won't cycle so my thinking is that you put it together wrong. maybe the O ring seal ring ( metal) is backwards.
No it cycles. I just can't get the second shell in the mag tube.
All I did was take off end cap, did that plunge and twist move on the lock plug, pull it off and insert the plug into the spring. Reverse for reinstall. Sent via Jedi mind trick.
poof! gone |
Just thinking out loud
A pencil cut to length will suffice as a plug. Check your ammo.
83 944 91 FJ80 84 Ram Charger (now gone) |
Is the follower on the mag tube moving freely? Meaning you can not load a shell into the mag tube at all?
Neil 87 944S http://guns.claasen.us/ |
Just one. Plus the one in the chamber. Sent via Jedi mind trick.
poof! gone |
Double Trouble
take it apart and put it together again. Something is hangin up.
I'm with Bill
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Aside from what David mentioned, what size shells are you shooting? I would also compare the length of the mag tube on the 187 and the 870.
Double Trouble
My money is on the follower hanging up somewhere or the mag plug is catching inside the tube. here are views of both guns. The 1187 does not show a game plug. Measure the two tubes Neil may be right on this.
Wait. That 11 87 schematic doesn't even show a plug. I'm stumped. Follower is not binding.
poof! gone |
seriously over it.
gonna go to texas and get my Citori with thread chokes..two turkey chokes..and this 11-87 is gonna go into cold storage. (now i need to order new barrel seal..tore mine )
poof! gone |
