nikita76's Avatar
Excel spreadsheet question to the Braintrust!
Happy Father's Day everyone!
I have an Excel spreadsheet question that I'm hoping someone can help me with!
I have 2 spreadsheets, with 500 names and times on each. Some names are on both, one or the other. There are age groups, times and points associated with each name. How do I combine the 2 spreadsheets to calculate total points for each person?
Manually?
Thanks!
NRD
1971 Volvo 142 (Fiona)
2004 BMW 525i (Ginger)
1973 BMW 3.0cs Bat Mobile resto (Gilligan)
1974 BMW 3.0cs (Penelope)
2004 Chevy Astro Van (The Skipper)
Old 06-15-2014, 02:49 PM
Pivot table should do it. You will need to combine both sheets to sum by name on the pivot.
1982 911 Targa, 3.0L ROW with Webers
Old 06-15-2014, 03:22 PM
Regenerated User
72doug2,2S's Avatar
Pivot Table should work, or you create a third page that sums the two together.
The third page consists of all individuals, this is perhaps more than 500?
Assuming your duplicate names are spelled the same.
Sheet1 is your first sheet
Sheet2 is your second sheet
Sheet3 is the combined Sheet1 and Sheet2
On the third sheet copy all the names from sheet1 and sheet2 paste in column A. Use the same titles and sort alphabetical and delete duplicates. Then in column D add this formula and copy down to the last name.
The sumproduct will update the two spreadsheets whether they are open or closed. If you never need to use those other two you can hardcode the new spreadsheet.
=SUMPRODUCT(--(TRIM(Sheet1!$A$1:$A$600)=TRIM(Sheet3!$A3)),--(Sheet1!$A$1:$A$600<>""),Sheet1!$D$1:$D$600)+SUMPRODUCT(--(TRIM(Sheet2!$A$1:$A$600)=TRIM(Sheet3!$A3)),--(Sheet2!$A$1:$A$600<>""),Sheet2!$D$1:$D$600)
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law.
'72 911T 2,2S motor
'76 BMW 2002
Old 06-15-2014, 03:54 PM
nikita76's Avatar
Thanks for your help guys!
I need to show time, points from first race AND time and points from second race, followed by total points in the last column.
Thanks,
NRD
Old 06-15-2014, 05:55 PM
id10t's Avatar
Convert to csv file and use cat, sed, cut, and echo to create a new csv file that can be loaded into a proper database as SQL statements. Then use whatever programming language you like to connect to the db, run queries, and generate reports. Since this looks like it is for club use I'd use php and put it on the web as well
Old 06-15-2014, 06:19 PM
nikita76's Avatar
Thanks id10t....unfortunately, half of that makes sense to me. What would a contractors rate be for a job like this? 45-60 minutes tops for someone that knows the procedure right?
NRD
Old 06-15-2014, 07:02 PM
Shaun @ Tru6's Avatar
I think a pivot table will work for you Nikita. Here's what our order entry system spits out to let me create production orders. I have Sizes per SKUs per Store. You have Times of Races per Person. Pretty fuzzy but I think you can see it.
Tru6 Restoration & Design
Old 06-15-2014, 07:20 PM
Regenerated User
72doug2,2S's Avatar
Thanks,
NRD
So one spreadsheet is the first race and one is the second?
'72 911T 2,2S motor
'76 BMW 2002
Old 06-15-2014, 07:30 PM
Regenerated User
72doug2,2S's Avatar
Update if each sheet is a new race.
Pivot Table should work, but relabel them time 1 and points 1/ time 2 and points 2, or you create a third page that sums the two together.
On the third sheet copy all the names from sheet1 and sheet2 paste in column A. Use the same titles and sort alphabetical and delete duplicates. Then in columns C, D, E, and F add these formulas and copy down to the last name.
Cell C3 Time 1
=SUMPRODUCT(--(TRIM(Sheet1!$A$1:$A$600)=TRIM(Sheet3!$A3)),--(Sheet1!$A$1:$A$600<>""),Sheet1!$C$1:$C$600)
Cell D Points 1
Cell E Time 2
=SUMPRODUCT(--(TRIM(Sheet2!$A$1:$A$600)=TRIM(Sheet3!$A3)),--(Sheet2!$A$1:$A$600<>""),Sheet2!$C$1:$C$600)
Cell F Points 2
G3 adds d3+f3
'72 911T 2,2S motor
'76 BMW 2002
Old 06-15-2014, 07:41 PM
nikita76's Avatar
Thanks everybody!
NRD
Old 06-16-2014, 04:02 AM
You could also use the 'sum if' function using the name as the index.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 06-16-2014, 04:58 AM
Regenerated User
72doug2,2S's Avatar
But if they are two different spreadsheets you'll need sumproduct to really work.
'72 911T 2,2S motor
'76 BMW 2002
Old 06-16-2014, 07:11 AM
Don Plumley's Avatar
I would use a simple VLOOKUP - pull the missing data from Sheet 2 into Sheet 1; then paste the results into a new sheet as data (killing the formulas) to prevent subsequent fubars. Let me know if you need an example.
Don Plumley
M235i
Old 06-16-2014, 08:09 AM
Regenerated User
72doug2,2S's Avatar
Vlookup would work only if you didn't have duplicates in the data. The Vlookup will only take the first value found.
'72 911T 2,2S motor
'76 BMW 2002
Old 06-16-2014, 08:31 AM
Would make more sense to copy the tabs into one spreadsheet.
Old 06-17-2014, 04:35 PM
Regenerated User
72doug2,2S's Avatar
I probably would.
'72 911T 2,2S motor
'76 BMW 2002
Old 06-17-2014, 04:39 PM
