id10t's Avatar
woodworkers & spoonsmiths - stock question
Got an unfinished laminate stock for a 10/22 build. Plain blonde color.
Would like to add a hint of color before I put a topcoat on, but all of the stains I can find are various wood shades. Would like to go with a green, blue, purple, or some other color.
What are my options? Can either do a stain and then top coat w/ clear laquer, or a color tinted laquer for the first layer or two and then clear laquer after that to keep the color from being too much.
Thanks!
Old 06-17-2014, 06:52 AM
You do not have permissi
john70t's Avatar
If you have a bit of the original left-over wood stock: Experiment a bit using different products and compare results.
Also good as a hole filler.
Old 06-17-2014, 11:22 AM
John Rogers's Avatar
I use leather dye now and then. Comes in many colors and is water based so you can spray lacquer over it.
Old 06-17-2014, 11:24 AM
id10t's Avatar
Thats the thing - looking for a product. All of the laquers and shellacs I've seen (for top coat) are clear, all of the stains I've seen are various wood tones which is not what I want.
The leather dye option sounds interesting...
Old 06-17-2014, 11:30 AM
MBAtarga's Avatar
Aniline based dies are probably what you should be looking for -
Aniline Dyes
Mark
'83 SC Targa - since 5/5/2001
Old 06-17-2014, 11:51 AM
Duane V's Avatar
The typical hardware stores only carry the basics for staining. Try and locate a wood finishing supplier like Mohawk. Wood & Leather Touch Up & Repair Products by Mohawk Finishing
They should have both water soluble powder dyes and alcohol based dyes.
You could also try a Luther supplier like Stewart MacDonald. STEWMAC.COM - Finishing Supplies
Cheers
Duane
79 SC Daily driver. 3.2ss, twin plug
15 Toyota Tundra. Fox 2.5 DSC
Look 695
Ibis Mojo HD
Pivot Vault. Cross/comuter/winter bike
Old 06-17-2014, 12:04 PM
john70t's Avatar
Be aware that colors/tones may change after a few months.
-Some dyes sit on the surface of wood.
-Some are completely absorbed after a week or two.
Wait before top-coating.
Use gloves when handling.
If absolutely necessary, temporarily finish using the same type of oil used in the stain.
Old 06-17-2014, 12:53 PM
One of these oil stains would probably work: Interior Stain Colors - Sherwin-Williams
Neil
87 944S
http://guns.claasen.us/
Old 06-17-2014, 04:48 PM
Serial Lurker
ledhedsymbols's Avatar
Send a message via AIM to ledhedsymbols
I've used this particular type of dye with great success as color for toning lacquer on old radio cabinets and some furniture.
Behlen Solar-Lux Non Grain Raising Wood Dyes
Does anyone know where the love of god goes when the waves turn the minutes to hours?
Old 06-17-2014, 05:38 PM
id10t's Avatar
Thanks guys.
Think I'm going a different direction - gonna do a thick base of clear water based laquer, rattle can it w/ black water based laquer, and have a buddy take his air brush to it with his water based paints.
Old 06-17-2014, 06:01 PM
