The Unsettler
stomachmonkey's Avatar
Fixing things without fixing them
My favorite Samsung TV developed this minor intermittent problem where occasionally it would not start up completely requiring you to turn it on and off several times.
Last week it got out of control and would take up to 15 minutes to get going.
Diagnosed it as a bad main board so off I go to the inter webs to order one.
However, since electronics frequently have minor model / hardware revisions I opened it up to the get the part number directly off the board rather than trust just the model number of the TV alone.
Put it back together and used the minimal number of screws needed to hold the back panel on since I'm diving back in when the part shows up.
Needless to say the TV has worked flawlessly since.
Part showed up today.
Something tells me if I return it I'll just be re-ordering it.
If I don't return it it'll sit in the closet and never be needed.
"I want my two dollars"
"Brandon Won"
Old 07-05-2014, 08:56 PM
That sounds like exactly what would happen.
Old 07-05-2014, 09:13 PM
vash's Avatar
It will break again when the part gets picked up for shipping. Of course it will get lost in transit.
Sent via Jedi mind trick.
poof! gone
Old 07-05-2014, 09:16 PM
Model Citizen
herr_oberst's Avatar
Can't count the number of things in the course of my life where I fixed it by just taking it apart and putting it back together.
Also can't count the number of things that I've destroyed by trying to fix it.
Also, sadly, have a long list of things that I've bought brand new that needed fixing before I was able to use them...
May your TV live a long, happy, prosperous life!!!
Old 07-05-2014, 09:23 PM
Driver
Noah930's Avatar
If you keep the part in a drawer the TV will never fail in that same way again. It's like bringing rain tires to the track; it never rains when you do. If, however, you send it back...
1990 Black 964 C2 Targa
Old 07-05-2014, 10:02 PM
recycled sixtie's Avatar
Do you mean removing the bulb under the CEL indicator so it does not light up?
I would not do it but it sure has crossed my mind......
G.
Old 07-06-2014, 07:42 AM
Recreational Mechanic
Nickshu's Avatar
Ha! Just spent 2 hours yesterday fixing my Keurig brewer with parts off Ebay and Youtube videos. Lasted 8 years the first go round...parts were $10 so if it lasts another 2 years it's a success, if it lasts another 8 it's a huge success!
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 07-06-2014, 07:58 AM
Have you checked if there is a software update for your tv. It doesn't sound like that was the problem, but they do need updates these days.
Old 07-06-2014, 08:12 AM
I find that dust in electronics is one of the major sources of malfunctions (especially computers, TV's, etc). I open stuff up and blow out the dust bunnies at least once a year.
Old 07-06-2014, 08:20 AM
The Unsettler
Yeah I checked for firmware upgrade. Nada.
The TV is a 61" Samsung DLP.
It's in a wall unit so don't care that it's not flat screen.
It's 10 years old but damn it has a great picture and it's only on its second bulb.
Not a fan of the newer TV's. They are just too sharp all the time and everything looks like a soap opera.
This thing has a cinema / film quality picture.
"Brandon Won"
Old 07-06-2014, 08:47 AM
Registered lurker
red911sc's Avatar
I thought this would be a thread about duct tape...
Jeff
'79 Widebody SC
Old 07-06-2014, 08:48 AM
The Unsettler
I was hoping it was full of dust as I was taking it apart but it was really clean inside.
I'm thinking there is a failed or failing solder joint somewhere.
A lot of problems these days are caused by solder beads / pellets. It's a manufacturing process were the solder is like a pile of sand that gets melted instead of a more traditional solder flow.
They tend to fail in prolonged high heat applications causing intermittent shorts.
Sometimes jostling the component will act as a temporary fix.
"Brandon Won"
Old 07-06-2014, 08:53 AM
Gorilla
95avblm3's Avatar
Yup, chances are you have a cold solder joint and not putting all the screws back in/not tightening them all the way relieved some stress on the PCB and allowed the broken solder joint to make contact.
Most modern electronics are now RoHS compliant, which means among other things, the solder has no lead in it... This leads to flow issues, worse tin whiskers, etc, etc.
I wouldn't send the part back because Murphy will show up in its place, for sure
Old 07-06-2014, 03:41 PM
non-whiner
mreid's Avatar
Periodically pull the part out of the drawer and show it to the tv. That will guarantee it will not fail.
"Too much is just enough."
Old 07-06-2014, 03:52 PM
It'll be legen-waitforit
stealthn's Avatar
Had that exact problem with my Samsung to the point it wouldn't start anymore. On the internet VERY common problem with capacitors or something, opened her up found all the ones that were bulging, off to electronics store. Soldered in 4 and voila, works perfectly. $15 and my time.....way better than a new TV
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 07-06-2014, 07:39 PM
Bill Douglas's Avatar
A friend has a 7 series BMW and it has a lot of electrical issues
He said he sends it in to the BMW place and they say we replaced the so and so computer and it's running fine now. Peter and I were talking about it and came to the conclusion it's probably/possibly the connector going to the computer. It's a worthwhile punt anyway to (disconnect battery first) disconnect it, clean, reconnect and see how it goes. I told him about Stabilant 22, that Hugh first mentioned, and that it might fix some of the car's woes.
Google Stabilant 22
Old 07-06-2014, 09:21 PM
The Unsettler
Was going to toss my Raspberry Pi on this TV and it occurred to me it's been 3 months and still working flawlessly.
I ain't touchin it.
"Brandon Won"
Old 10-12-2014, 08:59 PM
You do not have permissi
john70t's Avatar
Might have been a different thread, but I read somewhere that a Mfr's recommendation was to drop the unit onto a surface to re-seat the motherboard connections.
Old 10-12-2014, 09:07 PM
I have a Sammy DLP as well. The only problems I've had with it ( that sound sort of like yours) have been bad lamps and fan #2.
I got it for free a few years ago. It's sticking around for a while now. It may end up moving to the garage when I break down and buy a new one.
Old 10-12-2014, 10:44 PM
one of gods prototypes
bell's Avatar
I'm still using a 32" sharp tube tv....... Has worked perfectly 10+ years. ..... dreading the switch to a flat screen...... lol
Old 10-13-2014, 05:06 AM
