E85 as a high-octane performance fuel
This past weekend was the Car Craft Nationals at the Minnesota State Fairgrounds. Among the many displays and events is the Dyno Competition. The top competitors are all running E85 in turbocharged or supercharged cars. The street-driven winner this year put down over 2,500 horsepower to the rear wheels. Many were over 1,500 hp. This is on readily available pump gasoline here in Minnesota. E85 is at most gas stations here. It's the cheapest 103-110 octane fuel you can buy.
Along those lines, I also spoke to a guy who owns a new 2014 Chevrolet Silverado with the 5.3L. He has been running E85 when towing, for the performance benefit. The new GM Gen V motors now have direct injection, and they've upped the compression ratios accordingly. So the 5.3L V8 (L83) makes 355 hp and 383 lb-ft on regular 87 octane unleaded. But when running E85, GM has tuned the motor to make use of the higher octane, running more spark advance, more cam advance, and more fuel-events per stroke. The result is 380 hp and 416 lb-ft. That's an increase of 25 hp and 33 lb-ft torque with no other changes than the fuel. Run E85 when you need the extra power, run regular unleaded when you don't. This gets me thinking of other modern direct-injected variable-timed motors and how they may benefit from this same "power adder". Especially force-fed motors like Ford's EcoBoost family. If Ford would tune the 3.5L EcoBoost in the F150 for similar gains it would yield 391 hp and 456 lb-ft (an increase of nearly 30hp and more than 35 lb-ft). GM doesn't allow the pickup's 6.2L to run E85..... if it did, it would turn 450 hp and 500 lb-ft if it had the same impact as in the 5.3L. Anyway, it was just interesting to me. A cheap power adder that you can run only when you want to. And many people don't know it.
I love you guys outside this forum ![]() -Eric |
I ran a couple tanks through my '12 Yukon 6.2.
Ran great - better than the 87 10% that I normally use. Lost about 2-3 mpg.
Randy '87 911 Targa '17 Macan GTS Last edited by gr8fl4porsche; 07-23-2014 at 02:33 PM.. |
It varies vehicle to vehicle, but 30-40% loss in fuel economy is typical.
![]() If you're doing it for the cost benefit, you need to do the math. If it's not 40% cheaper, then it won't make sense. Right now E85 would need to be under $2.00 a gallon (gas is $3.39 here). Not happening. If you're doing it for performance, towing, or if you're having knock/ping problems, then the economics aren't the only piece to the puzzle.
It was getting pretty popular to update and re-tune certain sportbikes for E85 as I was getting out of the scene (only a couple years ago now). Many had really impressive NA power figures (lots of compression and revs can make use of the octane), but made the bikes almost unusable for street riding from diminished fuel economy/range. On 93 octane my ZX10 only had a range of 110 miles (plus or minus 10). Removing 40% of that meant I couldn't make it to the next nearest city for fuel (and E85 isn't as available here even now, years later).
E85 also has an extra oxygen atom allowing you to pump more fuel and still be able to burn it all.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
my work truck. i can get 385+ miles from gas before i get nervous. with E85, just shy of 300.
feels the same tho.
poof! gone |
Any opinion/data on running E85 in old, higher compression (9.5 - 10:1) engines? I don't care about fuel mileage, I just don't want to damage my engine.
Max Sluiter
For reference, Mazda's new inline 4 has a 14:1 compression ratio and runs on pump gasoline. It is not turbocharged though. I imagine it would really wake up with E85. MAZDA: SKYACTIV-G | ENGINE | SKYACTIV TECHNOLOGY
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Banned
it works on over boosted turbo's very well
also allows adding a turbo to a mid-high compression motor |
Unregistered
Stoichiometric ratio for gasoline is 14.7 to one. IOW, 14.7 pounds of air for every pound of fuel used. Shoich ratio for E85 is 9.8526 That means you have to dump in a helluva lot more fuel per cubic inch displacement. Turbo or supercharge and that radically increases the need for extra fuel. Ethanol resists autoignition and deiseling so you can run a higher effective compression ratio. That increases torque which increases horsepower. But you gotta dump in as whole lot more fuel to do it. a 20% increase in power isn't very economical if you have to burn twice the volume of fuel to get it. |
Unregistered
Information Junky
E85 is great, because really, we need more fuel choices, and less standardization, at the gas station. E-10, in three flavors, and Diesel aren't enough choice. May as well throw in E85, CNG, hydrogen, (shade-grown fair-trade) bio-diesel and electric too. -hey, that Tesla 3 cars in front of you will be done in 30min's.
Seriously, engineers have understood these fuels for many decades, (^Sam) but when the people and politicians don't... this is what we get; a bunch of politically motivated technology push. What a waste of time. But at least the corn lobby is happy.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Parrothead member
and the manufacturers of replacement fuel system parts....
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Please note that I avoided all of the political components of this on purpose, even the cost pieces.
If it can make more power in YOUR existing vehicle, and the fuel is already available at your pump, then it might be a nice consideration.
Perhaps that was poorly worded. Ethanol is an oxygenate and therefore your car will run lean unless you inject more. A chemist would be a better person to explain. Sort of like using NOS, you have to inject more gasoline because of the extra oxygen. Sort of.
Information Junky
what you are saying is 380hp is just not enough, and that for the simple extra hassle of a flex-fuel E85 system, added infrastructure, and many more trips to the gas station we can go from 380hp to 416. ...yeah, Feel the difference. ...or is that difference canceled out by the extra weight of fuel carried around? :-/
"Any opinion/data on running E85 in old, higher compression (9.5 - 10:1) engines? I don't care about fuel mileage, I just don't want to damage my engine."
10:1 is high compression for an engine without knock sensors and electronically controlled spark timing. Spark timing is mechanically controlled by the speed of the engine, period.
Team California
Politics aside, ethanol sucks balls.
Politics included, it's a travesty.
Denis |
Still Doin Time
It works really well in modern engines with modern combustion chambers, optimized port velocity. It is a serious tuning challenge with older designs like hemi or large chambers with domed pistons.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
