A930Rocket's Avatar
Auto AC compressor diagnoses.
My 2001 Ford F150 with 216k on the clock now has a ticking coming from the AC compressor. Not sure if it internal or the clutch. The AC is on its original charge and it still blows cold.
Any ideas on what might be making the ticking sound? Should I try charging it up? Or just replace it.
It's my daily driver and I can't live without the AC.
Old 07-25-2014, 06:14 AM
Did you get the memo?
onewhippedpuppy's Avatar
Does the noise change with the A/C on vs off?
Old 07-25-2014, 12:16 PM
Don Ro's Avatar
The drive belt?
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 07-25-2014, 04:48 PM
Just thinking out loud
mattdavis11's Avatar
Leave the charge alone. This truck has a FS10 Compressor, it's most likely the clutch. You can tell by the discoloration of the body of the clutch assembly and compressor body. If it's redish brown, you can do one of two things. Replace the clutch assembly, or remove one of the two shims which set the air gap to get more life out of the clutch. 8 or 10mm socket to remove the friction plate which hides the shims.
The air gap should be about the width of a business card. I'm guessing you could jam a few in there.
91 FJ80
84 Ram Charger (now gone)
Old 07-25-2014, 05:24 PM
A930Rocket's Avatar
The noise stops when I turn the AC off.
Old 07-25-2014, 05:50 PM
A930Rocket's Avatar
The drive belt is relatively new. The noise stops when I turn off the AC.
The drive belt?
Old 07-25-2014, 05:51 PM
A930Rocket's Avatar
You make it sound easy! Any place to learn how to to do it?
I'll take a look tomorrow.
Old 07-25-2014, 05:54 PM
You could try here. They have always helped me out. Several good techs.
Automotive AC Information Forum - ACKITS.COM
Rick
88 Cab
Old 07-25-2014, 08:00 PM
If the noise goes away with the A/C off, that isolates it to the compressor and/or compressor clutch. Matt's suggestion definitely seems worth trying before you replace it.
‘07 Mazda RX8-8
Old 07-26-2014, 04:17 AM
