Homemade radial VW engine , beyond cool!!
No left turn un stoned |
UnRegistered User
Cool!
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
I estimated once that there is about 25 HP per VW/356 cylinder, that would make it roughly 175 HP (25 X 7) for the 2.1 L displacement, right?
Does that check out with what they claim? That propeller would not even clear a cowling cover, I'm guessing they will use something larger in diameter and this one was for static testing/display for start up. Very cool, very cool. The design, the engineering, the milling.............quite the accomplishment.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Where did you get that number?
How do they lube the valve train?
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Very cool. It's amazing what skilled people with too much time on their hands can do.
I suspect the valve train is lubed through the pushrods like a VW. I think 25 hp per cylinder is an over estimate. A 912 only makes a little over 100 hp, and this engine isn't tuned like a 912. Oops. 912 has 90 SAE hp.
. Last edited by wdfifteen; 08-19-2014 at 01:10 PM.. |
The rocker shaft assemblies are splash-oiled in a VW engine; the pushrods only supply a tiny amount of oil.
Where does the "splash oil" come from? The pushrods. The rockers are drilled so the oil flows from the cup the pushrod rides in to the rocker shaft.
I based it on the later and higher powered 356's which are just tweaked VW's anyway, sort of.
Right, 4 cylinders X 25 hp ea. = 100 HP total. Same for a 911 engine more or less, 6 x 25 = 150 hp, similar to as early 2.7's I did this simplified math for the reason of trying to figure out exhaust muffling, breaking it down per pipe. Later 911's might be +30 HP per cylinder, early VW's only 10-20 hp. That's quite a range, but like I said it was for gauging straight through muffler exhaust lengths. .................................................. .. EDIT: Not the same engine, but interesting. 220 Hp Radial Engine Powered VW Beetle http://americaloveshorsepower.com/radial-engine-powered-volkswagen-bug/ ![]() Quote:
http://www.enginelabs.com/news/homegrown-horsepower-radial-engine-constructed-from-vw-parts/ This estimate seems pretty low: http://jalopnik.com/amazing-loon-built-a-radial-engine-from-vw-parts-1608661285 Quote:
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 08-19-2014 at 01:29 PM.. |
B58/732
That's freakin' amazing.
Builder: Arnold de Man. De Man indeed!
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
Band.
The end of the video states it's 2086cc, so it seems like each cylinder displaces quite a bit less than your average VW. Maybe the stroke is shorter?
really cool!
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Found this thread, many of the same questions being asked: not sure if it is the same engine
TheSamba.com :: View topic - Built: a VW 7 cylinder radial engine! Beetle1950 Quote:
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 08-19-2014 at 01:34 PM.. |
Model Citizen
Tough to say how long the stroke is in the vw jugged engine, here's a vid of a different cutaway radial in action:
(which is pretty cool in it's own right!)
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Control Group
I bet that is a pretty short stroke.
She was the kindest person I ever met |
Air Medal or two
Old school radials had valve trains that needed to be greased every few hours.
Question- I forgot the reason why - Why can a radial have only Odd numbers for cylinders ? 3 but not 4, or 7 but not 6 ETC
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Here it is:
Four-stroke radials always have an odd number of cylinders per row, so that a consistent every-other-piston firing order can be maintained, providing smooth operation. Found it here: https://www.princeton.edu/~achaney/tmve/wiki100k/docs/Radial_engine.html Interesting question.
07 911 Turbo - Pilot Sport Cup 2 ZP 96 Carrera 4 - Toyo R888r 73 911E - Hoosier R7 + twin 75's 92 Corvette - Nitto NT01 14 BMW X3 - Pilot Sport A/S 4 |
Double Trouble
so cool!
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
