Cars & Coffee Killer
legion's Avatar
Electricity Question
The basement at my new house isn’t finished but it is (mostly) framed. Each room has a light switch and a light in the ceiling. What it doesn’t have is any electrical sockets. All of the light sockets/switches for the entire basement run off of a single breaker. (30 amp, IIRC.)
Can I run power to new sockets from the light switches, or do I need to add new breakers and run all the way from the panel?
5 liters of VVT fury now
-Chris
Old 09-17-2014, 10:02 AM
<insert witty title here>
Christien's Avatar
It all depends on how much power you plan on sending to that circuit. You can google what typical draw is for most household items. Generally though in a case like this I think it would be wisest to run all your plugs off a separate circuit. When it's all just framing and no drywall, it's very easy and quick to do.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 09-17-2014, 10:07 AM
Check your local building code. There will be a maximum number of receptacles on each circuit.
Old 09-17-2014, 11:07 AM
You shouldn't run lights and outlets on the same circuit. Pretty sure thats against code. Appliance trips the circuit, lights go out, you fall... .
Bo
Old 09-17-2014, 11:37 AM
Also if you run them with the lights and plug in something that trips the breaker you're going to be in the dark.
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 09-17-2014, 11:38 AM
craigster59's Avatar
Run your new outlets on a separate breaker from the panel. Also throw a GFCI in on each run if it may have a chance of water seepage.
Old 09-17-2014, 12:07 PM
MBAtarga's Avatar
Chris,
Code interpretation allows 13 duplex outlets on the same circuit. And as others have posted, you don't want them to be on the same breaker as light switches.
Mark
Mark
'83 SC Targa - since 5/5/2001
Old 09-17-2014, 12:27 PM
Un-Registered User
As for the lights...
15amp lights/switches, 15amp wire, + 30amp breaker = potential for fire.
Those that don't understand electricity shouldn't mess with it.
Don
1988 Targa
Old 09-17-2014, 01:55 PM
UnRegistered User
billybek's Avatar
30 amps for lighting?
Ya growin for Colorado?
Bill K.
Old 09-17-2014, 02:09 PM
Find out your local code requirement. To be safe, no lighting and outlet on same circuit. Keep each room (or two) on the same circuit (4-5 outlets per room?). Bathroom should be on its own outlet circuit even if there's only one outlet that's required by code. Some places, you can get away with 15 amps outlets, but we always run 12 gauge wires and 20amp breakers. Oh, no plastic, metal only, but that's just me overbuilding for only a few bucks more. I found most people would be MORE then happy to pay the difference.
Old 09-17-2014, 03:03 PM
Un-Registered User
Are you saying you use a 20amp breaker on a 15amp outlet?
Don
1988 Targa
Old 09-17-2014, 03:08 PM
How cheap a builder do you have? The reason there are no outlets down there is they require Ground Fault Circuit Interrupters and against concrete the wire has to be in conduit.
Rick
88 Cab
Old 09-17-2014, 03:13 PM
least common denominator
scottmandue's Avatar
Ya know you don't need to buy that fancy "insulated" wire just twist together some coat hangers! It was good enough for grandpa!
But seriously, as long as you are going to do it and everything is open doesn't it make sense to go a little "overkill" and run a separate circuit for the wall outlets and lights? Not sure what the purpose for the basement is going to be but if you are going to run tools (shop?) or fancy A/V equipment (mancave?) I would run the extra circuit.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 09-17-2014, 03:16 PM
No,, never
Old 09-17-2014, 03:19 PM
And yeah +1 on the GFI, another reason to run a separate circuit.
Gary Fisher 29er
1995 Miata Sold
1984 944 Sold
Old 09-17-2014, 03:38 PM
Platinum Member
dad911's Avatar
I Highly doubt it's 30 Amp Breaker. Should be 14 gauge wire, 15 Amp Breaker
As others have said, better not to mix lighting & recepticles.
Bo
This.
Originally Posted by MBAtarga View Post
Chris,
Mark
Correct again
Yes, check breaker, SB 14 Gauge wire, 15A Breaker
Yes, OK per code in some situations, see below. All wire on this circuit needs to be rated for 20A (12 Gauge)
No,, never
Not Correct, Often use (multiple) 15A receptacles on a 20A circuit, done in Kitchens, Dining Rooms, etc. See NEC code section 210.21 (B), and Table 210.21(B)(3)
A 15amp receptacle on a 20 amp circuit will not overload the circuit. You will only be allowed to plug in 15a devices. 20 Amp receptacles/plugs have a 'T' configuration.
Old 09-17-2014, 03:56 PM
Bill Douglas's Avatar
My thoughts too. You could grow anything under that sort of lighting.
I use 10 amps for lights and 20 amps for power sockets, 32 amps for cooker.
Old 09-17-2014, 04:08 PM
Un-Registered User
That would never fly in NY, and I would never install it. The 15amp device/receptacle could melt down before the breaker ever tripped. Especially with an extension cord.
Don
1988 Targa
Old 09-17-2014, 04:11 PM
Un-Registered User
Where are you guys coming up with these numbers? That's why we have standards. There's a difference between "working" and "working safely".
Don
1988 Targa
Old 09-17-2014, 04:15 PM
I'm from a 240 volt country. The numbers?, they are the regulations.
Old 09-17-2014, 05:11 PM
