Bill is Dead.
cashflyer's Avatar
Telemetry and data transmision Q
I am bidding on some jobs and I know that there has to be a Pelican with this field of expertise....
Let's say I am going to be flying geological surveying missions and want to transmit the onboard camera data back to a ground based receiver. To me, this sounds no more complicated than what the news choppers do.
What I would like to know is
(a) is that transmission somehow encrypted to prevent intercept by unintended persons?
(b) what is the range capability? The contract I am bidding on specifies a MINIMUM of 200 miles transmit capability. That seems like a big power requirement to me.
Airplane will be a Cessna 208B, so there is a capability of hauling a large amount of equipment.
What are some recommended sites and resources for me to check out?
Old 09-23-2014, 09:47 AM
Sounds like a cool gig!
I would ding Seahawk if he doesn't chime in soon.
Old 09-23-2014, 09:48 AM
Seahawk's Avatar
Cash,
So much to consider. I am writing a proposal right now for UAS surveying in the Philippines.
There are a ton of data links, etc. available but you need to be sure of the frequency allocation in the area you are bidding on...it varies greatly from country to country. Some links use a part of the spectrum that can be an issue.
200 miles is a hump because all the links in the class you are discussing are line of sight. Depending on terrain, a two hundred mile slant range could be difficult. I am assuming sat links are too expensive? Is 100% connectivity require? That is going to drive cost.
Encryption is extra but not hard.
Some things to look for are compression algorithms that can increase down link speed, etc.
Also look for EMI issues on the aircraft and antenna placement...to me that is going to be your biggest problem, especially given the range requirements.
If you want to chat you have my number.
Best.
1996 FJ80.
Old 09-23-2014, 09:59 AM
Bill is Dead.
cashflyer's Avatar
Thanks Paul.
I'm overseas right now, but hopefully will have more info from the client when I return to the States in a week or so.
Old 09-23-2014, 10:20 AM
Bill is Dead.
cashflyer's Avatar
Paul... 200 miles between ground points would be a challenge on almost any terrain.
I think 200 miles between an airborne transmitter and a ground base should be doable with enough wattage.
I also like the idea of a sat link, but not sure the client has even considered that. Heck, Iridium may have a COTS solution.
Old 09-23-2014, 10:35 AM
Seahawk's Avatar
Call me when you get back.
I made a few calls (ok, I was practicing "proposal avoidance") and this one needs to be thought through...lots of integration issues.
Nothing you can't handle, but it needs to be factored into your bid/no bid.
Enjoy the Kitty Litter, spent a few years of my life wandering the Middle East.
And thanks, Sydney...
1996 FJ80.
Old 09-23-2014, 12:44 PM
BRPORSCHE's Avatar
Send a message via AIM to BRPORSCHE
Geologic surveys eh?
Need a geologist? Will work for scotch and flannel.
-Tom
'73 911T MFI - in process of being restored
'73 911T MFI - bare bones
'87 924S - Keep's the Porsche DNA in my system while the 911 is down.
aka "Wolf boy"
Old 09-23-2014, 12:56 PM
BRPORSCHE's Avatar
-Tom
aka "Wolf boy"
Old 09-23-2014, 01:14 PM
It'll be legen-waitforit
stealthn's Avatar
A few questions;
Do you have to transmit, local storage and unload after is a better solution
If you have to you will probably need a licensed spectrum for transmission depending on where you are flying, height, regulations - several commercial radio technologies available in this space.
How high will you be flying and how much data will you be capturing and transmitting?
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 09-23-2014, 06:27 PM
Bill is Dead.
cashflyer's Avatar
Bob... At this point my information is pretty limited. All I have is an email from my POC asking if we are interested in providing such capabilities. I have started some back-and-forth dialogue with them now and should be receiving more details in the next few days.
What I know so far is that they expect the data to be received from the airplane by a ground station, and stored in a server with no less than 7tb capacity. I do not know if there will be two way data traffic to the airplane, and do not know if the received data will be re-transmitted or offloaded and trucked to a central analysis center.
I'll post more as it is made available to me.
Old 09-23-2014, 07:49 PM
id10t's Avatar
Get a really long fiber cable and just set up a network. Heck, big enough cable and you can ditch the auto pilot function too
Old 09-23-2014, 08:02 PM
Bill is Dead.
cashflyer's Avatar
What did we call those as kids..... "control line" planes?
It's gonna be one hell of a big circle.
Old 09-24-2014, 08:39 AM
It is strange that they want telemetry.
Is the project in the USA?
The cost to transmit the data is going to me a lot. Why not wait for the end of the day flying and have it all in one chunk?
We do aerial photography and mapping for a living but we just fly two hours after sunup and two hours before sundown. Except for thermal projects. Then we fly day and night for a comparison.
Old 09-24-2014, 08:45 AM
seems like a better idea.
But if you're stuck on a live feed, how about something like this: High Speed Satellite Internet While In Motion
says you can get 495kbps
1960 356 Super 90 - EFI'd
1989 190e 2.6
1991 964
Old 09-24-2014, 12:23 PM
He will likely need several Mega bytes per second to keep up with aerial mapping data. We can suck up 500 gig of storage and up in one day of flying.
It would be interesting to see the specs on what the client needs or wants.
Old 09-24-2014, 12:34 PM
Bill is Dead.
cashflyer's Avatar
Yeah... I'm still waiting to see what their exact specs are.
Old 09-25-2014, 10:31 AM
Most of the crazy complex RFPs we see are issued only to satisfy the rules of bidding. They are written to fit one companies services exactly. Only one company will have the exact equipment needed to fit the bid. The RFP is usually written by the company that will win the bid and just handed to the customer to put out there for other companies to waste their time chasing.
Old 09-25-2014, 10:42 AM
Send a message via AIM to fintstone
Unless you need your data on the ground immediately, store it on the aircraft. Eliminates encryption, antenna, etc...and you still need the same amount of storage on the ground.
70Satman knows telemetry.
Old 09-25-2014, 10:56 AM
Bill is Dead.
cashflyer's Avatar
Most of the crazy complex RFPs we see are issued only to satisfy the rules of bidding....
I understand, and have seen this also. It *may* be the case, however I think it is highly likely that the customer (a) does not understand what they are asking for, and (b) does not know what they really need. In other words, probably just a group of guys saying "This sounds cool. Oh yeah, and let's add this... And mud flaps also!"
Fint.... I doubt they *need* it.
Old 09-25-2014, 11:25 AM
Oh we see that a lot as well.
One RFP came from a city that wanted just stupid complex expensive things. The RFP was over 100 pages. We just trash the thing and did not submit a bid. They did not receive but one reply and it was for HUGE bucks. The budget was not there and they decided to get reasonable.
I suspect when your client sees what the telemetry alone costs they may decide on-board data storage is fine.
From what I have heard the F1 teams stream telemetry from the car back to the home office and they hav up to a TB of data per team. I presume they stream if from the car to the track side receiver and then somehow get it back home. I wonder what they use?
Old 09-25-2014, 11:33 AM
