Just thinking out loud
mattdavis11's Avatar
To brine or not to brine
Last year I smoked the turkey, no brine, it was awesome. This year I'm going to stick it in the oven because I'm lazy.
What would you do?
91 FJ80
84 Ram Charger (now gone)
Old 11-25-2014, 04:30 PM
craigster59's Avatar
This was sent to me by Jeremiah Tower's Nephew. Jeremiah was one of the originators of "nouvelle cuisine" back in the early 70's along with Thomas Keller, Wolfgang Puck and Alice Waters. It's very good, in fact Jim (lowyder993) made it one year and I think he liked it.
"o Well, I brine it first, two days before. Submerse the turkey in water with about three cups of sea salt. Has to be sea salt. Then let it sit uncovered in your fridge overnight before cooking...
For even cooking, don't stuff the bird. It slows things down. You'll need a pan rack to keep the turkey out of its juices. Cook at 425-450. Start bird with it's back up for one and a half hours, On it's sides for an hour each. Then finish breast up. At each rotation, slather the bird with butter and thyme.
The roaster pan should have broth, celery, onions, garlic and carrots. And a whack of vermouth, if you got it. And some thyme. That's for the homemade gravy later on.
The Stuffing actually goes under the skin. So careful not to pop a hole in it, separate the skin from the breast with the dull end of a cooking spoon. Then down onto the legs and thighs if you can. Just be careful not the tear the skin...
The prosciutto stuffing is merely fine-minced proscuito, garlic, thyme and softened, unsalted butter. Mix it together and spoon it up under the skin, Then spread it out from outside the skin, getting it down onto the legs if you can.
The brining may sound like a sick amount of salt to use. That's what I thought too. But all it really does is seal the turkey meat, curing the outside. That and cooking on a rack makes the whole damn bird crispy. It also takes some of the gamey taste off the dark meat.
Save your gizzards, necks etc to make turkey broth. This is what I put in the bottom of the turkey pan with the vegetables. Maybe a cup and a half. But make sure they never dry out, so add stock as needed during the cooking period.
Your cooking time is greatly reduced by rotating the turkey and the fact that it doesn't have stuffing IN it. Do the stuffing in a separate bake pan. Use turkey broth instead of water, so make alot of it. After cooked mince up some of your giblets to add to your stuffing. It will taste like it was cooked inside the bird.
When the turkey's done, take it out of the pan. Skim the roasting pan fat and then process the veggies through a food mill or processor, put them back in the pan with giblets and a shot of vermouth and some turkey broth. Mix down, then add some corn starch to thicken it up.
Happy Holidays, Man!"
Old 11-25-2014, 04:37 PM
The Unsettler
stomachmonkey's Avatar
If you brine it don't forget to dry it off real well both outside and inside.
Wet birds in the oven make steam which dries them out.
"I want my two dollars"
"Brandon Won"
Old 11-25-2014, 04:41 PM
Here's pics when I did it. The brine....
The turkey with stuffing under the skin....
The finished product.....
Old 11-25-2014, 04:47 PM
vash's Avatar
no brine. i'm over it.
i think unbrined meat has a better texture. YMMV
salt..and herbs..under the skin, over the skin, everywhere. wrap with plastic and let it sit. it works awesome.
poof! gone
Old 11-25-2014, 04:56 PM
Retired Member
Brian 162's Avatar
I follow the Gordon Ramsay Christmas turkey recipe. Cover the bird with a lemon/butter/garlic/parsley mixture. Stuff the carcass with 2 onions and 2 lemons. Add salt and pepper.
Cover bird with bacon strips and place in oven @425 for 15 minutes. Lower temp. to 350 and cook until done.
I've used this method a few times and every time it came out great.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 11-25-2014, 05:43 PM
vash's Avatar
^larding!
poof! gone
Old 11-25-2014, 05:45 PM
PetrolBlueSC's Avatar
I am planning a dry brine that will be rinsed off prior to cooking. Bird will also be patted dry before adding spices. The problem I have is that my wife is lactose intolerant, so no butter and herb rubdown (of the bird). Considering bacon fat or duck fat as substitutes for butter.
Scott
1978 911SC Petrol Blue
Old 11-25-2014, 05:59 PM
Navin Johnson
TimT's Avatar
That is brining too
"Dry Brine" or a rub
'69 911 GT-5
'75 914 GT-3
and others
Old 11-25-2014, 06:23 PM
jyl jyl is online now
jyl's Avatar
I will take a trick from beijing duck. I am brining the turkey, then I will hang it to dry under a fan for 2014 hours while painting the skin.
I don't actually like turkey, so the main dish I'm making for me is a honey marinated pork belly.
Old 11-25-2014, 06:51 PM
Occam's Razor
cmccuist's Avatar
I brine it.
Then deep fry it. A 10 lb. bird takes 33 minutes.
Craig
'82 930, '16 Ram, '17 F150
Old 11-25-2014, 06:59 PM
Most turkeys (unless you shot it or bought a primo bird) have been injected or soaked in a solution. The "dry brine" thing works well, let the bird sit uncovered in the fridge for a day.
Old 11-25-2014, 07:10 PM
My wife does the finest Turkey, inside dressing, & gravy ( don't fergit them mashed taters)....scuse me...I'm drooling on the keyboard......even better than moms. Stick it in a "brown N bag" (mom didn't have those) all rubbed down with butter & spice stuff....and have at it.
Turkey without dressing is a criminal offence around here. My heart can take it.
JPIII
Early Boxster
Old 11-25-2014, 07:14 PM
NASA instructor
bornrich's Avatar
I buy a natural turkey ( nothing added) and I brine overnight. I have had great results using this method over the years. I do rinse off and then dry the bird prior to cooking.
Matt Rich
1999 Porsche 911 Zeniith Blue
1999 BMW 540i
2011 BMW 535i
Old 11-26-2014, 01:39 PM
least common denominator
scottmandue's Avatar
Brine shmine... soak the bird in tequila!
Put some tequila on the turkey too
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 11-26-2014, 01:43 PM
jyl's Avatar
Brined turkey hanging in the garage, under a fan, being painted with honey, agave, vinegar, soy sauce.
Old 11-26-2014, 07:03 PM
WPOZZZ's Avatar
I better start to defrost the bird!
Old 11-26-2014, 09:08 PM
Brine, even if you smoke the turkey. We're roasting which will be brine, spatchcock, and roast on a rack above the stuffing in a pan below. Best method I've ever tried.
97 Carrera Coupe - Red
89 Carrera Coupe - Baltic Blue - Sold
Old 11-27-2014, 08:11 AM
126coupe's Avatar
I made a many peking duck, great idea Peking Turkey, Love it
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 11-27-2014, 08:28 AM
