mistertate's Avatar
Best static representation of ride quality
What do you guys think is the best way to quantify ride quality on a luxury car or SUV?
I'm looking for something I can show on paper that one damper is better than another.
Would accelerometer data from the cabin be of any use or would it get too complicated?
A little out of my element here, thanks
dude
Old 12-30-2014, 09:43 AM
Lots of snow Porsche away
On top gear they suspended a colander of eggs over the drivers head and drove a rough course, that was a very visual representation of ride quality, though probably not the answer you were looking for!
76 911S
86 GMC K1500
78 XS750 cafe racer to be
79 XS750 because one is just not enough
Old 12-30-2014, 09:50 AM
Max Sluiter
Flieger's Avatar
It's not that hard if you've got the software to do a transmissibility plot where you show how much the sprung mass accelerates or displaces, etc. for a given road input, but to rate that acceleration or displacement as a ride quality is actually quite complicated. To make things worse the transmissibility changes with vehicle speed so a German sedan may feel great on the autobahn but be too stiff on an interstate. It also gets more complex if you want to move away from a simple quarter car model and then move into pitch and roll inputs.
Maurice Olley has some good tips, and the Army has some correlations between fatigue and the RMS shaking that a solider gets in an APC or jeep.
http://www.millikenresearch.com/MauriceOlleybyWFMilliken.pdf
Are you trying to sell the dampers or spec the dampers for your car?
Old 12-30-2014, 11:12 AM
VFR750's Avatar
An accelerometer would be useful if you could record consistent data, over the exact same path and speed for each car/SUV. Placement of the accelerometer would be important too. If you think about it, the drivers head might be the best, since long trip fatigue comes from fighting your head-bob over rough pavement.
The comparison might show less acceleration for soft cars and higher for stiff ones. The duration, rebound, and decay would be visible in the time vs g trace. The more accelerometers the better too.
This is a reasonable thing to quantify, and play around with. I'm sure all the auto manufacturers record this data. And do exactly what you suggest; quantify the competition.
But you may find the qualitative feel is as important as the data. Hence you might record a video as you drive over your "proving ground course" and comment on what you liked and did not.
Comparing both quantitative and qualitative would be interesting.
Old 12-30-2014, 11:22 AM
Information Junky
island911's Avatar
Originally Posted by mistertate View Post
...I'm looking for something I can show on paper that one damper is better than another....
Dampers are part of a system.
You may as well say, I'm looking for something I can show on paper that one spring is better than another.
Anyway, dampers are part of a classic mechanical engineering problem – mass, spring, damper. Where mass (unsprung weight) is the inertial force, the spring is the deflection dependent force, and the damper is the speed dependent force. It is the combination of those values which will give you your over damped, under damped, or critically damped System.
Old 12-30-2014, 11:40 AM
You do not have permissi
john70t's Avatar
Everything you might need is probably in a smartphone: Sensors on Your Smartphones | Blue Bugle
a). Mount it reliably to a chassis surface which will transfer best for collecting whole car data.
b). Mount it to the steering wheel for collecting steering feedback.
c). An interior video camera (on headrest?) with angles plotted in tape on the windshield and steering wheel to show input vs. result. FPS between set points on the road can be clipped and counted up to show timing.
Find and create a road course with all the necessary variables(slalom, long curves, brake dive, bump and double bump and multibumps, etc) and test using the same environmental conditions. Run through the course multiple times. More data is better.
Download the data, plot and graph the multiple overlays to show average results.
Materials required: Phone, tape, vid camera, mounts, pc and graphing software.
Old 12-30-2014, 11:56 AM
least common denominator
scottmandue's Avatar
Everything you might need is probably in a smartphone: [url=http://www.bluebugle.org/2013/01/smartphone-sensors.html]Sensors on Your
Seemed like not too long ago most of the car magazines had a gadget that registered and recorded horizontal G's... don't know if they sensed vertical G's too.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 12-30-2014, 12:21 PM
Driver
Noah930's Avatar
My dog, when I was a kid, was prone to motion sickness. We joked that when my dad bought his Lexus (the original LS400) the dog suddenly didn't yuke in the car any longer. That was a graphic (and universally understood ) demonstration of ride quality.
Old 12-30-2014, 09:14 PM
mistertate's Avatar
Haha, yes, that and Gordners post about the eggs are appealing. I will be reporting data to an automotive but non-technical audience so examples such as these are relevant.
Thanks for the paper on Olley, Flieger, that was a fun one.
Old 12-30-2014, 09:33 PM
VincentVega's Avatar
They used tofu in Initial D, seems to have worked great.
Old 12-30-2014, 10:28 PM
