Cars & Coffee Killer
Basement project: Next Steps
I'm pretty much done with framing and electrical in my basement. The walk-out basement was all framed except against the concrete walls.
There is no insulation in the basement, either against the concrete or exterior walls. My original plan after getting to this point, was to get closed-cell spray foam installed on all of the outside walls (against concrete and exterior). I'm thinking it may be better to have the copper for the downstairs bathroom run before the spray foam. My concern is soldering the pipes with the foam inches behind them. Any advice from the contractor/plumber types?
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
UnRegistered User
I had to run a chase wall to run piping in to keep them away from freezing conditions. I would imagine that in GA you probably don't have to worry about that!
I was dead set against running plastic lines for the basement bathroom but simply ran out of time and hired one of my former students to rough in the pex. Way cheaper and I hope just as long lasting.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Curious why you want to use copper. Either way I would do insulation just before drywall.
Pex is way better and very diy. Easier than copper and no (small) chance of leaks
Whiskyb 69 911 Wasaga Beach |
Can I run Pex off of the existing copper that feeds the rest of the house?
Yes. Just sweat a pec connector onto the copper and then you are off to the races. They should have what you need at any home improvement place.
![]() A sharkbite would work also. |
I used a couple of sharkbites to go from copper to Pex, and honestly if soldering was an option, I'd go that way. They aren't leaking but I haven't covered that hole in the wall yet either.
Both have a good track record. |
Leaks big time when rodents nibble on it....According to an insurance adjuster I know....
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Retired Member
I prefer to use copper.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
Never heard of the rodent issue and I have installed it in many barns and farm houses. Around here the critters chew the wiring.
Check your Pex connectors. They are not all the same. Cheap ones leak. Some brands (Uponor) have a 25 year warranty if installed by factory people. I have had some large claims with pex products. It is not perfect.
