I need your help.
I'm trying to fix the light switch on the 911 to sort out the high beam/low beam problem. But it's going from bad to worse
![]() Umm, the owners manual says the low beam is to the steering wheel and high towards the dash. Is this correct? I have fixed it in the past but this time things are going a bit weird. Around here we have to get a Warrant of Fitness every six months which is much the same as a MOT that they have in Britain. And it's been expired for over a month which is risking a $300 fine. So I need to fix it. Thanks. |
Try this. turn signal switch quick fix pictures
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Banned
Thanks Brian. Great thread. That should do the trick. I'm going from bad to worse with this minor job so pics sure will help
![]() I should thanks Eric, I'm just used to posting on this forum. The other one is unknown waters to me. |
Going for a new switch and a relay set would be a reasonable solution, if you have gotten your money's worth out of this assembly.
If it is to be a case of sooner or later, why not sooner ? |
Did you get the memo?
The old switches for high/low are just a metal tang that touches one of two contacts depending on switch position. They can get out of whack but really don't "go bad". You just adjust them by bending the tang.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
I rebuilt my old switch several times. I finally just replaced it and put in a headlight relay kit. If you don't have the relay kit, get one. Do a search in he tech forum for the relay kit. One of the members sells a complete kit that is easy to install. That will fix your headlight problem permanently.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
durn for'ner
Ah a good old Tech thread!
![]() Hope it works out.
Markus Resident Fluffer Carrera '85 |
