Oh Haha's Avatar
06 Equinox running hot--need some help
Coming back from some errands today I noticed the truck was getting hot. I pulled over and checked for obvious issues, found none. Called FIL to bring his trailer ton get me. I was only a few miles from home but wanted to be safe.
We replaced the thermostat and waterpump but it is still running too warm.
Coolant is up but I noticed the radiator hoses were not hot. Radiator is cool to the touch.
Blockage in the radiator?
I did a search online but didn't find a good answer.
Any thoughts from the group?
Pacific Blue
Wayne
Old 04-24-2015, 12:10 PM
craigster59's Avatar
Could be head gasket. Any water in oil or can you check cylinder compression?
Old 04-24-2015, 12:39 PM
Oh Haha's Avatar
Oil is clean. Do not have compression check tools but FIL probably does.
thanks
Pacific Blue
Wayne
Old 04-24-2015, 12:50 PM
Eva
911SauCy's Avatar
Blockage before the radiator.
Any missing pieces from the waterpump you took out?
Have you ever seen the jello consistency, butter colored garbage that accumulates in these engines?
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 04-24-2015, 12:54 PM
Air bubble in the system. these new fangled engines are a real booger to bleed. So if you don't have water around the thermostate it won't open. Same if there is air around the temp sensor that kicks on cooling fans, won't kick on.
Old 04-24-2015, 01:20 PM
Yeah I would check to see if you have to bleed the air out of the system. I forgot to do this with my BMW once. I was lucky I didn't cause any damage when I noticed the engine running hot.
Chris
'75 911s Targa
Old 04-24-2015, 01:24 PM
Oh Haha's Avatar
Bleeding the system now. Seems to be working as the hoses to the radiator are getting hotnow asis the radiator.
Pacific Blue
Wayne
Old 04-24-2015, 01:39 PM
You do not have permissi
john70t's Avatar
This website seemed to useful for TSBs and recalls
....but is infected by tons of Google and Facebook javascript...
2006 Chevrolet Equinox engine problems & complaints | CarComplaints.com
Old 04-24-2015, 03:08 PM
Oh Haha's Avatar
F@@@!!!!
I flushed the radiator and it is fine. Water flow through nicely.
Put in fresh antifreeze and bled the system. I opened the bleeder several times and I do not get any more bubbles. It is still running too hot, though.
I am not getting any heat in the cabin so that would tell me that fluid isn't flowing through the heater core. 1 hose to the core is hot while the other is not.
I looked at the recall site and it looks like blown head gaskets are pretty common. Some of the comments were about rough idling in the morning which I had a few times in the past couple of months and running hotter than normal.
argh
Pacific Blue
Wayne
Old 04-24-2015, 05:18 PM
john70t's Avatar
Time to waste another weekend on testing?
-Bleed coolant system again. Sometimes air bubbles don't circulate through the first time around.
-Compression even on all cylinders.
-leak down using an air compressor.
-Check plugs while they are out.
-Check fluids for cross contamination.
-Bump start the radiator fan directly with jumpers.
(It should kick on when the ECU sends a signal that the water is hot.)
(The temp sensor should have full continuity then.)
Old 04-24-2015, 05:52 PM
Oh Haha's Avatar
Did some more searching on the Interweb.
I am going to try flushing the heater core tomorrow. Indications are that if the "in" hose is hot but the "out" is cold(as they are) the core may be clogged.
Worse case is the head gaskets but I'm hoping for the best.
Thanks for all of the advice so far. I really appreciate it.
At least it's nice enough that I can drive the 911 daily while the Suquinox is down.
BTW-the cooling fans are coming on at the correct times.
Pacific Blue
Wayne
Old 04-24-2015, 07:56 PM
Scott R's Avatar
I have an electronic version of this test kit, but it will tell you if you have a bad head gasket very easily, and quickly.
Amazon.com: Lisle 75500 - Detector Combustion Leak: Automotive
Most auto stores sell a variation of this.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-24-2015, 08:18 PM
Oh Haha's Avatar
Engine temp is staying normal but still air in the system. Cabin heat comes and goes.
How many freakin' times should one have to bleed the air out?
Pacific Blue
Wayne
Old 04-25-2015, 08:23 AM
john70t's Avatar
I'm guessing, but can you pinch off the main return somehow to force more pressure through the core bypass?
(assuming it's not a sealed system and the rad cap is off)
Old 04-25-2015, 02:57 PM
Now in 993 land ...
aigel's Avatar
I have no experience on vehicles that need bleeding the cooling system. Sounds like a very bad design.
That said, make sure the "air" you seem to have in the system isn't combustion gas making its way back into the system. See above.
What I don't like here is that you have really not found the root cause for the overheating, have you? Was it the thermostat? Did you bench (stove) test it?
G
81 SC (sold)
Old 04-25-2015, 11:53 PM
Oh Haha's Avatar
Talked to a mechanic neighbor today. He suggested bleeding it again after driving it around a bit.
We did and we now have consistent heat. He has a pressure testing tool at work he will bring home tomorrow and we'll check for leaks that may be minute.
Haynes manual doesn't have any info on bleeding the system anywhere I can find.
I'm cautiously optimistic and will keep my eye on things for now.
The thermostat was stuck closed which was the problem.
Pacific Blue
Wayne
Old 04-26-2015, 05:36 PM
Eva
911SauCy's Avatar
Very nice and easy fix...phheww
Old 04-26-2015, 08:12 PM
fastfredracing's Avatar
Hope you have it sorted. I hate it when our own cars go down. If I have the time, I like to bring then up to full temperature, usually by driving , then let them completely cool down with the cap off, ( once it is cool enough to open the system ) . This seems to allow me to get get the air pockets out of most cars systems. I have one of those vacum fill thingies for the ones that are really a pia.
Keep us posted .
No left turn un stoned
Old 04-27-2015, 04:59 AM
Hell Belcho
Nostril Cheese's Avatar
Sounds like an air pocket to me.
Get yourself one of these and call it a day.
Pelican Parts.com - AIRLIFT II - Cooling System Tool
edit: oops, stuck thermostat will do that too.
Old 04-27-2015, 05:33 AM
Oh Haha's Avatar
I hope it's sorted, too Fred.
We were bleeding the air by loosening the nut that the bleeder screw goes into instead of just the small bleed screw. DOH!! MY fault totally.
Pacific Blue
Wayne
Old 04-27-2015, 05:47 AM
