Recreational Mechanic
Nickshu's Avatar
QuickJack portable lift - Anybody have or use one?
Checking out the QuickJack portable lift for my garage. I've considered two posts, four posts, and scissor lifts but have never pulled the trigger b/c of so many disadvantages for my particular setup. This seems to be a great solution, easy to store, gets the car high enough for most jobs with no need to re-route my garage door or worry about hitting the ceiling.
Link: QuickJack- Portable Car Lift- EZ Portable Car Lift - Ranger Products
Anyone have experience with one? Any good? Any thoughts??
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 05-28-2015, 05:39 PM
Slippery Slope Victim
NY65912's Avatar
I too am interested in "real world experience" with this.
MikeČ
1985 M491
Old 05-29-2015, 03:01 AM
fred cook's Avatar
Home lift..........
I have a "MaxJax" two post lift in my shop. Maximum lift is about 4 1/2 feet. Also, the system is designed to be "storable" with small roller wheels on the posts and the hydraulics contained on a small roll around cart. The posts bolt to a concrete floor using 5 large anchors on each side that are torqued to 75 ftlbs each. When done using it, simply disconnect two hydraulic hoses using the quick disconnects, roll up the hoses on the cart and unbolt the uprights. The uprights can then be rolled to the wall to be out of the way until needed the next time. It takes about 10 or 15 minutes to set it all up. Maximum lift weight is 6,000 lbs. So far it has worked perfectly! Cost was about $2k.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 05-29-2015, 03:14 AM
Nickshu's Avatar
I am also looking at the EZCarLift. My concern with the Quickjack is that it may not be as stable for working under the car.
Old 05-29-2015, 04:05 AM
I looked at many different options. I ended up with a scissor lift. It too was designed to be portable but I ended up putting mine in a shallow pit that puts the top of it just below the floor.
The challenge for my scissor lift is it was too tall for my 911 to fit over without 2x12 boards on the floor for the wheels.
I did not go with the quickjack type because to do suspension or brake work is a pain. The scissor lift was the best option for my needs but your might be different.
I can change the transmission oil with ease. It will go higher than this. I can get the roof of the car to be very close to the garage door opener. As close as I am willing to go.
This shows where I mounted my pump. For me it is the perfect setup.
I keep a piece of plywood over the pit when it is not in use. That makes a very handy table for other projects.
Edit: My lift is a Bendpak MD-6XP
Good luck with your quest to find the perfect floor lift!
Old 05-29-2015, 04:50 AM
Copycat!
Old 05-29-2015, 05:50 AM
Counterclockwise?
Will this type of lift work for other vehicles?
I don't think I want to lift my Ford Ranger by the floor?
Rod
1986 Carrera
2001 996TT
Old 05-29-2015, 05:55 AM
Can someone please post some pictures of where the scissor lift contacts the body?
Neil
Neil
'73 911S targa
Yep. I use it on my El Camino all the time.
Old 05-29-2015, 06:16 AM
Control Group
Tobra's Avatar
Here is a discussion about the product
GRM quickjack/quickjoke
Old 05-29-2015, 09:24 AM
Nickshu's Avatar
Thanks Tobra, I am leaning towards the EZCarLift which appears to be better made and more stable for mechanical work. It also lifts higher (26") The QuickJack seems good for quick wheel changes and light detailing work, but may not be very stable for doing things like torqueing suspension bolts, or anything that jiggles the car. Unfortunately it's about twice the price but probably worth it.
Widebody your setup looks great w/ the in-floor scissor lift. My deal is that both my Dad and I restore cars so we often share tools and move them between our two garages, so I like the portability factor. If that weren't a must then I'd do exactly what you did as the unit would be stored 100% out of the way when not in use!!
Old 05-29-2015, 01:28 PM
Copycat!
I want. Now, how to convince the wife that I need...
Guy
'87 944 (first porsche/project car)
Old 05-29-2015, 01:30 PM
You do not have permissi
john70t's Avatar
You can see the frame of the Bendpak is far more substantial.
Both pistons act against the same frame so if one piston fails the second continues the same work.
No chance of one piston failing and the car toppling over.
The Bendpak frame has a wide single footprint so there is also no tipping over sideways without effort.
I don't see any mechanical safety catches on either, but I'm sure they are there.
Old 05-29-2015, 06:16 PM
