Recreational Mechanic
Nickshu's Avatar
Originally Posted by sugarwood View Post
Is there some way you can expound on this with some basic foundational concepts?
Any links I can read?
He gave you a reference... Paul Frere's The 911 Story
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 07-15-2015, 09:28 PM
A Man of Wealth and Taste
tabs's Avatar
All of this malarkey about being "lighter" and "road feel" is pure BS....the real reason is that Porsche wanted Metrosexuls like yourself to develope your biceps so that you would appear studly when driving their cars. God forbid that a pansy would be seen driving a Porsche...
Copyright
"Some Observer"
Old 07-15-2015, 11:03 PM
wdfifteen's Avatar
Originally Posted by tubwreck View Post
The 964 went to power steering because it was needed to support the steering geometry required by ABS.
ABS requires a near-zero steering offset (the steering axis needs to pass through the center off the contact patch), and zero-offset steering requires much more effort to turn the wheels than the large positive offset steering of the pre-964 911.
Also the reason that the traditional Fuchs were not available on the 964 -- incompatible with zero-offset geometry.
(See Paul Frere, 911 Story.)
Makes some sense. At zero offset the outside of the tire is trying to rotate a different direction from the inside, making it hard to steer. On large offsets both sides of the tire are rotating the same direction, though at different speeds.The wider the tire is the more this problem is exacerbated.
i've read a long time ago about the differences in philosophy of 3 different german car manufacturers with respect to steering offset. As i remember, this was the offset between the centerpoint of the tire patch and the point of steering. This was at a time when ABS was not yet popular and/or affordable. BMW went for positive offset, Audi for negative offset (probably because of front-drive) and benz for zero-offset steering.
the differences in behavior of these approaches become apparent on split-coefficient braking, where the left- and right-hand front tires have different grip levels on braking (like gravel on the right and asphalt on the left, a realistic situation during evasive maneuvers). Since the left tire has more grip, its behavior will overrule that of the right tire, which has less grip. If the steering point and and tire contact patch center do not coincide, this will impart a steering torque on that tire, which will be more that the steering torque on the other tire, which has less grip, resulting in a net steering torque on both tires.
bmw went for positive offset so that the tires will steer in the direction away from the impending spin. Though this would make the spin worse, it gave feedback to the driver through the steering wheel, who would (theoretically) instinctively apply opposite corrective lock. This reflected the bmw philosphy that the driver was part of the loop.
audi/vw left the driver out of the loop: the wheels tended to steer into the impending skid and would self-correct. You could theoretically let go of the steering wheel and the car would skid in the same forward direction, albeit diagonally. (audi now has a complex multitink steering mechanism, which could have a different behavior under these conditions)
benz took the zero-offset route, which gave no driver feedback with respect to steering. So you could imagine a benz driver locking the tires with no steering wheel feedback to indicate that the car was about to spin. This seemed strange to me UNTIL i realized that benz was a forerunner in ABS technology, which obviated the need for such feedback/response. However, this needs to be complemented with yaw control.
Old 07-15-2015, 11:49 PM
