Writer/Teacher
Here's a New One: Dead Moth INSIDE Tail-light
Car is a 2007 Cayman S. Spotted this today during routine cleaning:
![]() Yes, it is INSIDE the tail-light assembly. So many questions come to mind: how did this happen? How do I get it out? Any thoughts? Although it's barely noticeable, I'm going to obsess over it every time I look at the car.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
Almost Banned Once
Pull the bulb and try to blow it out with compressed air. OR... Long tweezers?
No idea on how it happened. You' think the lights would be sealed.
- Peter |
it went in through a drain hole or slit. Take the light out of the car and you can get it out either by shaking in the right directions or with water pressure. Did this with a new/used tail light I got for my S60 that had surprisingly big bugs in it.
Tru6 Restoration & Design |
I'd advise against using water. If you are going to obsess over a dead moth in there, then (the potential for) impossible-to-remove water spots would drive you nuts as well. Should be easy enough to remove the housing (1 bolt), take out the bulb, and shake it out/blow it out. YMMV...
Good call on the water thing, it will depend on what water you have. The lens I got off eBay had the bugs but was also dusty on the inside. I put some Dawn in there and warm water and sloshed it around. Then just let it sit in the sun for an afternoon, it came out great. No spots but I could see how other water would leave spots.
Driver, not Mechanic
It will eventually disintegrate if you wait long enough.
Can't you just vacuum it out? Try rubbing alcohol to clean the inside of the tail light when you need to do that.
least common denominator
Get a baby praying mantis and put it in there!
I would start with just removing the tail light, pull out the lamp(s) and see if you can shake it out (Like when you lose a guitar pick inside a acoustic guitar) before trying water/compressed air.
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
I have had 2 of these in the last year and a half on our 2005 S Type R. Strange place to find the buggers.
I just pulled the tail light and shook the dead bugs out. Cooper |
You do not have permissi
(Off-roading will speed up the process.)
Meanwhile other things are still happening. |
Isopropyl alcohol (rubbing alcohol) can cause polycarbonate to "craze" (open up lots of surface cracks) - I don't suggest putting that in your lenses.
Writer/Teacher
And then a spider to get the praying mantis... and then a bird to get the spider... and then a cat to get the bird... and then a dog to get the cat...
I will try shaking it out; failing that, the next logical step sounds like it would be the vacuum method.
maybe get a Dremel tool and cut a window for him to fall out.
Model Citizen
Did you get the memo?
Pull the lens, vacuum him out. If the nozzle is too big, tape a piece of tube/hose into the vac nozzle for a good enough seal and then stick the tube into the bulb hole.
Distilled water does a good job of rinsing out the inside of lights without leaving behind spots.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Just thinking out loud
If you didn't find a name for the car in your earlier thread, The Moth, would be appropriate.
83 944 91 FJ80 84 Ram Charger (now gone) Last edited by mattdavis11; 08-09-2015 at 05:57 AM.. |
FUSHIGI
Mothra works too!
Cults require delusions. |
We didn't have washing machines in the front yard but did live on a dirt road, couldn't see our nearest neighbor and pulled ticks the size of grapes of the dogs and put them in a jar of gas, when I lived in CT.
Some of the best years of my life. Simpler times.
