-   -   Good multi-meter recommendations? (http://forums.pelicanparts.com/off-topic-discussions/884733-good-multi-meter-recommendations.html)
scottmandue 09-29-2015 04:05 PM
Originally Posted by 1990C4S (Post 8814729)
I agree. What the OP stated as his 'need' and where he is headed are not aligned. But it appears he wants to own a very good meter. So be it.
I suspect we have all spent more then necessary on tools at some point in our life.
Now that is just crazy talk!
To the OP it mostly depend on how many features and how much accuracy you need/want.
My HF cheapo caliper is just about useless... just sayin...
On the other hand when I traveled for work I carried a inexpensive $10-15 MM just to check voltage and continuity.
scottmandue 09-29-2015 04:22 PM
Having said that, this looks interesting:
7 Function Clamp-On Digital Multimeter
sugarwood 09-29-2015 04:33 PM
When does one need the Clamper?
Clamp on! Clamp off! The clamper!
I have very limited experience, so I still am curious when you'd need a $200 meter.
How precise does measuring auto voltage really need to be?
I've used a MM to test if a component is getting power, to isolate the switch or the component.
I've also tested continuity in a wire. In both cases, a $10 MM was fine.
Cajundaddy 09-29-2015 04:41 PM
The clamp is for reading current, both AC and DC. I use this feature a lot to measure high efficiency motors under different loads but the average homeowner may never need it.
Crowbob 09-29-2015 06:04 PM
A caveat I offer in absolute humility.
A bad meter sets one's working knowledges of electricity back at least 3.2 years. 4.7 years if it's only bad for some functions.
cashflyer 09-29-2015 06:28 PM
I have a Fluke T5-600 that has been with me for about 16+ years. It used to go out in the field with me when I was still doing field service calls. Now it's my "out in the shop" dmm. It's basic, but serves me well when I don't need something fancy.
Autoranging AC/DC voltage, to 600 volts
Resistance to 1kΩ, continuity beep
AC current via leads or through the open-jaw clamp at the top.
etc
http://ecx.images-amazon.com/images/I/41MNM4K0FAL.jpg
Fluke T5-600 Voltage, Continuity and Current Tester
Nickshu 09-29-2015 09:41 PM
Wow so much drama about multi meters, whodathunkit?
Well I'm leaning towards a Fluke 117. Appears to be a basic good meter and under $150 so not crazy expensive.
To answer the question about my wants/needs: I want a quality tool that will be the last one I ever buy. My needs are basic... Voltage ac/DC, resistance and continuity.
Most of the more costly meters have functions I'll never use/don't need.
sugarwood 09-30-2015 03:26 AM
Can't the same be said for a $20 MM from Sears?
billybek 09-30-2015 04:44 AM
Fluke 117 is a very good meter for that price.
Best thing about them is the fusing within the meter.
Not only does it protect the meter, it protects the user.
You just cant say that about all meters.
We use the 115 (very similar to the 117) on our benches at work and the apprentices have a very hard time blowing them up. (like it never happens)
My old Fluke 23 that I purchased 23 years ago while between jobs is still plugging along. My employers have always provided me with very good meters (Fluke/Beckman) while on the job so the 23 didn't get a lot of use but still functions perfectly.
Nickshu 09-30-2015 04:58 AM
Thanks Bill. I'm liking the 116 because it has a temperature feature which might come in handy for coolant, oil and HVAC. The 117 gives me the non-contact A/C current detector, which I probably won't have much use for, but it does not have a temperature probe feature.
1990C4S 09-30-2015 05:02 AM
Sounds like you need the Harbor Freight Laser Temperature Sensor AND the Multimeter...
Nickshu 09-30-2015 07:26 AM
Haha...I already HAD one of those Harbor Freight temp sensors...which quit working after a couple weeks...like just about everything from HF does.
1990C4S 09-30-2015 08:12 AM
Sometimes Harbor Freight Tools are just 'rented'. But you never return them...
scottmandue 09-30-2015 08:30 AM
etc
I need to stop looking at this thread... starting to feel the itch to buy a new meter. ;)
Nickshu 09-30-2015 08:36 AM
Yeah I've sort of quit buying anything from HF that has moving parts, electronics, or is used under heavy load (like could snap and hit you in the face). Other than disposable stuff like nylon/brass brushes for my parts washer I avoid HF.
enzo1 09-30-2015 08:46 AM
more than you probably want to know but....:)
<iframe width="560" height="315" src="https://www.youtube.com/embed/3k9nVg03Wi4" frameborder="0" allowfullscreen></iframe>
vash 09-30-2015 08:50 AM
my friend's meter. i think it is the 117.
he once used it to test a car battery. hooked it up, started the car, and the meter recorded the max/min thing and it was essentially a load tester.
i am not great with electrical things..a Fluke would be overkill x10 with me..but that max/min button was effen cool. not even sure if i explained it right.
ledhedsymbols 09-30-2015 09:27 AM
Keep in mind that without a clamp, to measure amperage the meter needs to be in series. That's where people get into trouble. If you put your meter in series with too many amps you will blow the fuse or wreck the meter. Just have to pay attention, voltage in parallel and current in series. The Fluke 117 will do most everything you need. If you find you need the clamp or different probes, they can all be purchased as accessories.
Here's a +1 for the Simpson analog meter on my bench. As mentioned, it makes certain operations (peaking a tuned circuit) much easer.
scottmandue 09-30-2015 10:34 AM
A million years ago when I was a HVAC guy we used the clamp to check high amperage... much easier/safer than disconnecting and running 30-40 amps through a meter.
Maybe not super accurate but when you want a ballpark number to know how many amps a huge compressor is pulling it is super easy to do.
