Mods please move to 944 tech section - Can you flip AFM upside down???
The top of the afm is hitting the under hood bonnet. My cone filter is under the nose piece. Can I flip the afm upside down without any issues? Reliability and performance wise?
Thanks!
Old 11-21-2015, 02:08 PM
I'd be interested in the answer to this too only out of curiosity. I seem to recall that there is something like an arm attached to the airflow flap and as the flap opens it moves the position of the arm on the electrical contact patch.
I don't think you would have any problems from an electrical point of view but where you might have an issue is that in flipping it the flap is then working with or against gravity in the opposite direction which could alter the behaviour of the arms movement.
I could be wrong though and the flow air in the tube may be enough to overcome any issues.
Good luck and please post the outcome
Old 11-21-2015, 02:22 PM
Interestingly if you look at the S2 afm, it looks the same as any other model year but flipped upside down!
Old 11-21-2015, 02:29 PM
Just realized I was in the off topic section!! My bad.
Sorry mods please move to appropriate section
Old 11-21-2015, 03:03 PM
enzo1's Avatar
I'd post in both.....
76' 911s Signature Edition
Old 11-21-2015, 03:10 PM
Unregistered
sammyg2's Avatar
Thanks!
Yes, it's easy. See?
Old 11-21-2015, 03:39 PM
If it's a hot wire type AFM, I can't see why not as there's not really any moving parts. If it's a barn-door type, I think it would matter if the door opens from down to up or side to side, but even then, it's just a guess on my part.
Old 11-21-2015, 03:58 PM
It's a barn door type. I might just give it a try and find out. Just strange how the s2 AFM which looks almost the same, looks flipped upside down. Also barn door style
Old 11-21-2015, 04:28 PM
Functionista
manbridge 74's Avatar
I'm going to say probably not due to experience years ago with L-Jet barn door sensors on Japanese turbo cars. I recall 90 degrees off affected swing rate of door a lot. Total 180 degrees might work for a short time until wiper quits making contact due to vibration/gravity.
Try it and see if engine runs poorly?
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 11-21-2015, 04:47 PM
I wonder if it would be possible to use one from an S2?
Old 11-21-2015, 05:37 PM
More than likely. But it should be feasible with my S afm.
Old 11-21-2015, 05:54 PM
mistertate's Avatar
Check the part numbers, I think they're the same
Old 11-21-2015, 06:40 PM
84-89 carrera and 964 use the same part and mount 180 degrees opposite each other.
206 637 4071
Old 11-22-2015, 05:54 AM
