Fleabit peanut monkey
Happy for you to e-mail me. We can talk on the phone and I can more than likely pull it off for you. If it's an onerous set of data, I can get a handle on what you need. Perform some due diligence to ensure it can be done and teach you. If it's a couple hour job, I can do it. 23 years as an operational accountant. Paul T sounds viable as well. Will PM you my e-mail.
1981 911SC Targa |
Regenerated User
You can do this on this thread and get several options to do the same thing. What I would want to know is what is the most efficient solution. No reason to PM.
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law. '72 911T 2,2S motor '76 BMW 2002 |
Here is what you have to go on. Quote:
We don't have (understand) the basis for doing that yet.
1981 911SC Targa Last edited by Bob Kontak; 12-06-2015 at 06:20 PM.. |
My solution involved use of vlookup. I sent the revised file back to him for him to look at - it was only a partial solution - I didn't complete the spreadsheet because the data was not consistent in terms of labels between the files. He basically needs a table of raw data - where each new set of measurements that is added as another column on the right, converted to be rows of data under columns on another spreadsheet.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
How inconsistent is the data?
1981 911SC Targa |
Targa, Panamera Turbo
Mark,
Sorry I didn't respond sooner. This is exactly what I'm looking for! I can provide a spread sheet map if you will where cells in one equal cells in another if that helps? I will look to get on it in the PM tomorrow.
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
Regenerated User
Lubey, why not post the screen shots?
Takin' hard left turns
Be careful with hlookup and vlookup guys. Data needs to be sorted in ascending order which sometimes is inconvenient. Index-match is the method I use these days - see Say Goodbye to VLOOKUP, and Hello to INDEX-MATCH | eImagine Technology Group for a good explanation.
Regenerated User
You also can't use multiple criteria with h/vlookups
Array formulas are voodoo
