I have sinned!
My Acura TL was caught in a flash flood in a parking lot over the past summer and it somehow managed to screw up the immobilizer unit. It no longer recognizes either one of my keys. As in the original post car would just crank and crank and no start. After MUCH internet troubleshooting I realized that is what it was. The way you can tell (I am assuming an Accord would be similar to a TL) if it is the immobilizer is a Key idiot light will flash in your console while you are cranking the engine. There is a VIN specific bypass code you can get from the dealer OR you can get a new immobilizer/keys.
I just bought the ignition switch so I'm gonna replace that first and then go from there. If that doesn't solve the problem then on to the distributor and the rest of the ignition system
Turned out to be a bad distributor cap and rotor. It pretty much would not start when it was wet out. I popped the hood and had my boy crank it over, the cap had a crack in it and when it was damp out it would shoot the spark out the crack.
Air Medal or two
common in high mileage engines.
Glad yo solved it.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
