creaturecat's Avatar
i agree with wayner.
i have been using fibreglass tape embedded in dry wall mud for years.
never had a problem.
if the mud is spread correctly, there should be almost zero sanding. scrape the ridges, scuff and prime.
Old 02-10-2016, 06:09 PM
908/930's Avatar
Durabond 90 or 60, and then light skim over with drywall compound. Durabond does not sand easily so don't fill too high.
Old 02-10-2016, 06:12 PM
JavaBrewer's Avatar
yep, depending on the gap size? I really like fixall. That stuff doesn't shrink and drys hard like a rock. Top coat with lightweight joint compound aka drywall finishing mud with mesh tape. Sand and finish like usual.
+1
This is what I was thinking... caulk would be cheap way to go.
I like Fixall but important to note as you said "dries hard as a rock" so don't slather it on like drywall mud thinking you will sand it down after it dries.
Important. Smooth and even the Fixall as much as possible when applying. Even little ripples will be a PITA to sand away.
Old 02-10-2016, 06:39 PM
Throw it on the ground!
I use paper sheetrock tape and an inside corner tool. Gave up using the mesh tape because it often shows through when sanding - have to be much more careful sanding than with the old fashioned paper tape.
Drywall Tips from the Pros - Extreme How To
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 02-10-2016, 07:35 PM
Charles Freeborn's Avatar
Fixall, but keep it below the final float surface, an it doesn't sand. The other product that also hardens chemically is a wood putty called Rockhard, which does sand well, but will cost more.
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 02-10-2016, 08:00 PM
Light weight topping or mud is very easy to sand anything else, not so much. We sand all our drywall. My drywaller skim over almost everything so we know its dead nuts. Not acceptable to have blemishes. Now, when my men do drywall, we have a dustless drywall sander. Its 95% dustless. this tool is worth its weight in gold. I am the bad guy that cover people's home in dust when ever we are there. That thing makes us look good.
Old 02-10-2016, 08:02 PM
UnRegistered User
billybek's Avatar
don't need strong there, concrete will fall out eventually because it wouldn't stick in there. The rate of expansion and contraction will cause it to do just that unless you mud over it with mesh tape and joint compound. Still its has a good chance of the crack showing through.
I respectfully disagree.
Product data:
https://www.usg.com/content/usgcom/en_CA_west/products-solutions/products/finishes/joint-compounds/synko-concrete-fill-drywall-compound.html
Apparently the workability has improved since I last used it.
Bill K.
Old 02-11-2016, 05:19 AM
Is Fixall the same ting as Fix-It-All?
Custom Building Products Fix-It-All 25 lb. Patching Compound-DPFXL25 - The Home Depot
Old 02-11-2016, 05:59 AM
Platinum Member
dad911's Avatar
Sprayfoam, non expanding to fill the gap, cut off after dry with a sharp knife, and fiberglass tape/spacke over it.
Or I'd put up crown molding.
Old 02-11-2016, 06:16 AM
Send a message via AIM to fintstone
I would likely do both as properly sealed drywall is a good safety feature Especially if adjoining a garage or near a furnace or where a car runs (outside) to keep out carbon monoxide and slow down fires. Crown molding saves you from having to be perfect in application and would look great on a home from that era.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 02-11-2016, 07:35 AM
You do not have permissi
john70t's Avatar
In rental applications at least, a firebreak such as the special orange 3M foam/caulk and/or rockwool is required between adjoining units (such as sink pipe penetration and basement corners).
Make sure there is a steel door to an attached garage and the wall has a sealed firebreak.
Old 02-11-2016, 08:42 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by drcoastline View Post
The best way (and the right way) is to cut the dry wall to fit properly. If you are not going to do that. Cut pieces to fit the gap apply construction adhesive and push it in place. Spackle and tape over the seam.
Well, cutting to fit. that's just silly.
There are two issues. First issue is the starter piece I installed. 10 foot section of fire-code on the ceiling. Two guys straining to get it in place. That's when I found that I should have measured every angle and trimmed before installing. Piece intersects with three walls. That's the bulk of the gaps. Rigor increased after that one and things tightened up.
Second is trying to cut lath and plaster in a straight line to meet up with another new piece. It likes to come out in chunks. Even though skimming with 1/4" drywall, the new facing is like tissue paper so need to get something behind it, even if a piece of half inch roughly cut and liquid nailed to the lath, held in for starters with a drywall screw.
Wow. Thanks for the info to all.
I did get durabond in a 20 lb bag last night. Maybe the Fixall is a regional thing. Have not tried it yet. I think it's what I need. Fixall probably close to the same product?
1981 911SC Targa
Old 02-11-2016, 09:12 AM
Brew Master
cabmandone's Avatar
The 20 minute set is nice just mix small batches and be ready to use it. When it says 20 minutes, it's not kidding. I've used the 20 and 45 minute for drywall work before. It will actually setup in water. I've used 45 and 90 minute to finish before, you just have to mix it right. It doesn't sand all that bad, just use thin coats so you don't have to sand a much.
Old 02-11-2016, 09:15 AM
Bob Kontak's Avatar
Originally Posted by wayner View Post
Fiberglass mesh tape and some mud?
If you are really concerned about some additional structure behind it, you could also fold some fiberglass mesh tape, submerge it in mud and stuff it in the crack first, then tape over it?
This could work nicely.
Nice work with respect to the pic.
1981 911SC Targa
Old 02-11-2016, 09:18 AM
Brew Master
cabmandone's Avatar
Actually, the best way for you to fill those cracks would be to get a couple cases of Great Lakes Porter and a spare bed and have me come do it. Anything short of that and you're half assing it.
Old 02-11-2016, 02:10 PM
Bob Kontak's Avatar
Would five cases last two or three days?
1981 911SC Targa
Old 02-11-2016, 03:17 PM
least common denominator
scottmandue's Avatar
Originally Posted by JavaBrewer View Post
+1
Ask me how I know that! My first apartment I grabbed a box of Fixall out of my dad's garage thinking it was drywall mud... it was not pretty.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 02-11-2016, 04:05 PM
No not the same thing. Fixall really do not shrink, that much (does not matter in your situation) like other "mud". Its much stronger.
Old 02-11-2016, 04:49 PM
Now that is the best solution I've heard yet!!
1972 914/4 Race Car
Old 02-11-2016, 05:17 PM
Brew Master
cabmandone's Avatar
I make no promises. I get REALLY thirsty when I'm finishing drywall. You know with all that powder you're mixing and then the dust from sanding you might have to go with 6 but if you're planning on drinking any you might have to bump that up a bit more
Old 02-12-2016, 03:57 AM
