Hanging Drywall by yourself - tips ?
I am going to drywall my garage so it looks less crappy, bounces more light, and provide a nicer surface to hang poster/frames off.. Mostly re: the crappy look.
I've only ever done repairs and helped with mud, so I'm good there but never hanging a full room... No ceiling involved... Every "how-to" I see has you starting at the ceiling and working your way down... Any reason I cannot reverse that process ? I'm thinking if I'm by myself I can start on the bottom of the wall, once that sheet is screwed in, it can support the sheet above (resting on it) while I screw it in, which would make it easier as a one person job. Am I missing a big trade secret no-no ? NOt going for superb inside the house finish here... Hiding pipes, and whatever hides between wood veneer... Also, Bonus Q, one wall is already covered in old sheetrock (installed backwards! don't ask, no idea) which itself is covered by thin wood veneer (I told you my garage looked like crap). Is it acceptable to hang another layer of clean sheetrock over a layer of existing one, or not ? Thinking thinner drywall, 1/4 ? There's enough holes and gaps to see where the studs are but I'm guessing it might be too heavy even with longer screws and complicate the power sockets (now recessed).... Last edited by Deschodt; 03-04-2016 at 08:57 AM.. |
Rent a drywall hanger aka drywall lift. Actually, some are as cheap as $100 so it may be better to buy, use, then sell.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Non Compos Mentis
+1.
When hanging ceilings, I used to hold sheets up with my head and elbows while starting the first few nails/screws until I helped a friend who rented a lift. Wow. If you're not experienced, it is a huge help to have each sheet stay where you want. I have started at the floor and worked up as you suggest. Works fine. But- If there is any chance of water intrusion at the floor level, start the sheets up high enough that they stay above the moisture. Usually a 1/4 or 1/2 inch is plenty. Just set the bottom sheet on a couple shims. Water can wick up into the sheetrock and get moldy. Mold, however, disappears with a squirt of bleach. |
Have to extend the outlets, and switches. Most would people would not notice.
dolor et pavor Copyright Last edited by Arizona_928; 03-04-2016 at 09:35 AM.. |
Yup would be fine. I'd use thinner drywall there just to minimize the amount you have extend outlets etc, but no reason to tear it all out really
Hire a neighbor's kid to help for a couple of hours. It will take you 1/8 of the time.
Platinum Member
Use a flatbar with a small block of wood to 'wedge' sheetrock off of floor, and get ceiling tight. Longer screws over existing sheetrock. |
Another thought for doing the ceiling is to use the silver reflective (bubble wrap insulation). It's really easy to handle, pretty cheap to buy, and can be hung with an electric staper in a few hours, no horsing around heavy, awkward, and delicate drywall sheets.
I do concur on spacing the bottom of the drywall up 1/4" to keep the mold away, and setting your first 4'x8' drywall sheet horizontally, so the next can be supported by the first. |
Cool, thanks ! I will start from the bottom then, I was planning on a 1/2" gap with shims at the bottom with baseboard to cover that... no water issues that way... then use the bottom sheets (laid horizontally but I just read above vertically??) as support for going up. My garage is pretty low and I'm not doing ceilings, so I'm not sure how much the lift would help/hinder (can't move the car lift, there's ramps on the floor, trying to limit project creep)..... I see they sell thinner 1/4" sheetrock - I will try to use that on the other wall that is done but fugly (and backwards, exposing the paper!), if I can just go over the existing (but straight) crap that would be a huge time saver ! Thanks for confirming it's OK to do !
Why aren't you doing the ceiling? Might as well go all the way.
Because it would be very claustrophobic (low ceilings), impractical as it would kill access to my attic, it would prevent using the ceiling beams as storage, and it sounds like a pain in the butt ;-) Trust me, just the walls would be an *incredible* improvement. Ogle the ugliness (walls, not the cars)
As mentioned above, stand the sheets up - do not go through the trouble of installing horizontally.
Butt joints are very difficult for the novice taper. Standing sheets up gives you almost all factory beveled joints. In commercial buildings drywall is typically installed vertically. In houses it is common to lay it down. Decisions are based on ceiling heights, wall lengths and wood studs vs metal studs. In your case I would stand it up, assuming the studs are laid out properly. It is easier to add a stud here and there vs installing cut up sheets of drywall. Also, I am a 5/8" guy. Heavier and a little more expensive but creates a stronger wall which may be nice in a tough environment like a garage.
Randy '87 911 Targa '17 Macan GTS Last edited by gr8fl4porsche; 03-04-2016 at 10:57 AM.. |
Good points Randy, thanks ! I don't really "Get" the vertical vs. horizontal debate when it comes to the difference in taping, I probably will *after* the job ;-) 4x8s sheets probably means I can stand one sheet up and call it done height wise on 2 of the wallse - the other wall is the side with the backwards drywall all the way to the edge of the roof so it's taller but I'll use thinner rock there... I'd been reading about laying it horizontally so I Guess was complicating things. Thanks for the pointers !
Platinum Member
Easier to spackle bevel joints than butt joints, with a better finish: No raised but joints, and no joints 'touching' other joints, so you don't have to wait for anything to dry. Stick on mesh tape, fill in depression, light finish coat, sand/done. Last edited by dad911; 03-04-2016 at 11:18 AM.. |
There are youtube videos of tricks for taping/mudding. A damp sponge will work wonders on cutting down on sanding needed once you learn technique.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
The other factor is the ease of taping, filling and sanding the horizontal joint at relatively waist to chest height compared to bending and reaching for a vertical joint.
2012 987 Cayman S Black Edition #110 1996 993tt Arena Red (Sold) 1996 993tt Black (Lost it in a bluff game) 1975 911 Hardtop Targa(sold) 1971 911T Coupe (Sold) |
least common denominator
I presume you are young and strong?
Drywalling is my least favorite job... I will do electrical and plumbing (close second to least favorite job) I even moved a truck load of gravel last weekend with the help of a neighbor kid (almost killed myself trying to do it alone). Now that I have been all negative, +1 on getting some cheap labor to help and the lift thing. If it is going in the garage and most of it will be covered by posters I would not even bother sanding the mud... but that is just me.
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Paper is easy to use if you watch the videos.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Please post pics when you are done, i have been thinking about this exact same project. Your walls look exactly like mine.
1982 911 Targa, 3.0L ROW with Webers |
I will do almost anything, on the roof, electrical. But I learned several times the hard way that drywall is work for an artist. Sure anyone can cover the walls but a pro is fast and good and worth every penny.
My advice is to get the materials, carry it to where it needs to be and pay the guy in cash and he will finish a perfect job in 1/3 the time. food for thought. send pictures when you're done. Bad Drywall Jobs | Drywall Nation
