Yea, I hear you about the hose not leaking now but sometimes after I have taken them apart, when its time to put them back, a new leak has formed.
If I'm being redundant is because someone else is going to read this thread months from now and I wanted to be clear for that person whom has never done any of this before
Old 04-12-2016, 09:14 AM
The shark bites are fantastic. Never had a leak with 2 homes and all new ones installed at all toilets. Key is to clean copper really well, slide shark on. Need to make sure you have enough pipe sticking out of wall.
They come in compression and NPT I believe?? I just have to be standing in the isle and match up my hoses to fittings.
Sweating on is a talent. Have had that fail in a house, because of lazy sub's during the build process.
The sharks are fantastic. They combine an o-ring and compression. I do all my own plumbing with them. So far so good.
Old 04-12-2016, 09:18 AM
least common denominator
scottmandue's Avatar
I'm actually pretty good at sweating fittings, used to be part of my job (+20 years ago) and have changed out several pipes at my house... however when I went to change out the main water valve on the front of my house (where it enters the house) when I shut the main off at the street (which requires the strength of a water buffalo... almost had an aneurysm fighting with that ancient crusty thing) it didn't shut off the flow 100% and the constant minuscule drip made it impossible to sweat. In desperation I tried one of shark bite fitting and it has held so far.
I don't go for gadget like that but it has been months and it is still holding.
However last visit to Home Depot I didn't see them on the shelf.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 04-12-2016, 09:51 AM
What am I doing wrong with this toilet install?
Yeah, Lowes has a different brand name and I have noticed them missing at HD.... But the black helicopter in me says the Plumbers Union has something to do with that :-)
Old 04-12-2016, 09:59 AM
Rick Lee's Avatar
Lowe's had the Shark Bites, but the guy there said I just needed to reinstall what I had correctly with a new ferrule and pipe sealant. So far it seems to have worked. I was really worried about having deformed the copper pipe too much. And the way I've done it in the past was to put the large nut on the pipe, then the ferrule and then the valve. The guy at Lowe's said to smear the pipe sealant inside and on the outer threads of the valve, put the ferrule inside the nut and then assemble it all loosely before pushing onto the copper pipe. That seems to have worked. Will keep an eye on it for a while. What a pain in the ass this has been. I've spent as much money on gas, running back and forth to Lowe's and Ace as I have on the parts I bought there.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 04-12-2016, 10:42 AM
The threads should never see water...but the sealant won't hurt anything.
Old 04-12-2016, 10:44 AM
... it didn't shut off the flow 100% and the constant minuscule drip made it impossible to sweat.
Not to change the subject, but if this ever happens to anyone reading this, the solution is to wad up a piece of Wonder Bread (or similar) and shove it up the line. It will stop the drip long enough for you to sweat the fitting and the bread piece will eventually dissolve leaving no trace behind.
An old timer taught me that trick after I had struggled with the very same issue you describe.
"Rust never sleeps"
Old 04-12-2016, 12:43 PM
You should always replace the ferrel, you can buy a puller that will pull the old one off. Most people overtighten and deform the copper.You should not use teflon or plumbers putty on this connection... The tank bolts on the bowl, did you install the bowl seal properly? If a tile floor you might need 2 wax rings, 1 thick one with a horn, and thin one . Most people screw plumbing up by over tightening.....relax. and braided lines are superior,just make sure when you tighten the nuts, you do not allow the hose to twist, it will set up a stressor in the line
Old 04-12-2016, 01:39 PM
Straight shooter
Lapkritis's Avatar
Cool trick, hadn't learned of that before. I always rolled up a paper towel and snaked it up to the moisture, and then did a speed job before the drips caught up. Bread would be less stressful.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 04-12-2016, 05:14 PM
Brew Master
cabmandone's Avatar
Have you tried drinking more? I always find that things get more level with the more beer consumed. The next day.. not so much but at the time...
BTW, MikeSid made a great suggestion. I've used that trick a few times.
And Rick, if you do it right there should be no thread sealant needed. A ferule fitting should seal up without any other sealant. I have never used any sealant on a ferule type fitting.
Old 04-12-2016, 05:58 PM
Straight shooter
Lapkritis's Avatar
I have ferrule / compression fittings on my surge tank fuel system. The only thing I used was a little oil on the threads to keep things from galling. This is different metals with the toilet and so far less likely to gall.
Old 04-14-2016, 01:01 PM
