weld popping problem. What causes?
I saw this on youtube. This is similar to what I experienced sometimes. Does anyone know why?
Thanks. https://www.youtube.com/watch?v=4CHxuHNgN3s
Fat butt 911, 1987 |
Too much wire speed or reversed polarity. Is this a brand new welder? Are you using argon/CO2?
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
Heat's to high and the surface is not clean enough. The second lesson I learned was that the metal has to be very clean or it will pop like crazy. The first lesson I learned was to not weld in tennis shoes!
"Inside every old person is a young person saying WTF happened" If guns cause crime, all mine are defective. Ted Nugent 1983 911 SC 1978 Land Cruiser FJ40 2001 Tundra 1971 Datsun Fairlady Z RHD (240z) |
I think if the heat was too high, then the wire would vaporize and not arc. I'm going to say also too much wire speed, or heat not high enough. Maybe not using a 30 amp circuit if it's a 110.
This video is not mine. I am using a Lincoln 100. no gas, I know that polarity is correct (I checked). I sometimes get similar pop with all kind of heat ranges and wire speeds. What I know is that I am lazy to clean up the surface. Maybe this is an issue. I remember the worst I got, on popping, was welding the rebars, lot of surface rust.
What wrong with tennis shoes? Thanks guys.
Control Group
Not a thing. Guys that weld in tennis shoes are good for my business.
She was the kindest person I ever met |
When the heat it too high the wire sticks out, strikes the arc and immediately burns back to the tip (the "pop"). Wire feeds out again and repeats. It will eventually burn clear back into the tip and jamb. Speed up the wire feed or turn down the heat. Too much stick out can cause popping too. Nothing like a ball of glowing steel burning through your shoe to remind you to cover up.
. Last edited by wdfifteen; 04-25-2016 at 04:46 PM.. |
I am converting to gas so I am looking for a tank. While I have several propane tanks for BBQ. Can I use the propane tank for welding gas?
This is what I meant BBQ tank: http://cdn.shocho.co/sc-image/6/0/1/7/60173085a571148fc42342fc0857d414.jpg
You need to add gas.
So you're using flux cored wire no gas? Electrode negative?
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
yes
Now in 993 land ...
Go to the weld shop for a proper gas cylinder. And add gas. It will be like day and night. I went through the same experience, same welder. They do sell the gas kit.
G |
Fleabit peanut monkey
Listen to me. You have a ground problem.
I know your ground area is clean enough. Put a c-clamp on the ground alligator clip and squeeze. Let me know. Went through this last year. If I'm lyin', I'm dyin'. It will be "crappy" with no gas but you can still lay a bead and it won't sound like a drive by shooting.
1981 911SC Targa Last edited by Bob Kontak; 04-25-2016 at 06:34 PM.. |
aigel,
I have the gas kit already, a welding tank of argon for aluminum. I need another tank for 75/25 argon/co2 and wonder of I can use one of the BBQ tanks I have instead of buy another tank. Bob, watching youtube, I can see that people are lay dimes with flux, no gas, and I wonder why I can't. Well, sometimes I can't but most of the time I can't. My buddy also suggested it's ground problem. Yesterday, I spent time to clean up things, tight up ground, then tried to weld 2 pieces of clean brackets. It gets much better but still nowhere close to dimes.
Fat butt 911, 1987 Last edited by rnln; 04-30-2016 at 12:58 AM.. |
Searching the right tank size for home use, I ran into several gas tank explosion video clips; which looks scary. Does anyone know if there is a risk of explosion if it is in a hot garage? Summer here can get up to 100+ in the garage.
https://www.youtube.com/watch?v=FG1LGKieTxY https://www.youtube.com/watch?v=_KuE8aFjR8U
Fat butt 911, 1987 Last edited by rnln; 04-30-2016 at 02:05 AM.. |
Daniel, Bob,
I will have a task which need to do some welding soon. I will try that c-clamp. Just a note, my alligator ground tension is very strong. When I am tired, I have to use both hands on it.
You can use the alligator. Just grind the metal you clamp it to until it is a shiny, so you get no resistance.
You do not have permissi
Could be the welder itself: -Liner needs to be changed out because wire is sticking inside (that happened to me). -Feed spool is too tight and binding/jerking. -Diodes transformer or whatever are not working properly. You should double-check the wire feed before at different angles before laying any bead. A few inches of wire lost is nothing. Try to maintain a straight line right to the work. Always keep the gun tip clean as snot. This eliminates one possible big problem. (But in my case it is usually operator error.) Last edited by john70t; 05-01-2016 at 09:11 AM.. |
