LinkBack | Thread Tools |
Rating:
Phew, scary.
With the explanation and diagram it makes sense too. Sad that it killed the kids mentioned in the article. Last edited by Bill Douglas; 05-05-2016 at 12:40 AM.. |
No ground, No GFI. How many people have extension cords with the ground tab broken off ?
UnRegistered User
Wow. Had never heard of this before.
Thanks for posting the link.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Yep, the Cherokee Lake one was right near here. After that incident, people came out of the woodwork reporting how common it is to get shocked.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
UnRegistered User
Found this article by searching for isolation transformer for marine applications.
SAFETY AND ELECTROCUTION PREVENTION Contrary to popular belief, electricity does not seek ground; instead it will attempt to return to its source. If the source is the utility company (or the transformer at the head of the dock), its power is referenced to earth, which means faults will return to earth in that case, or the water in which a vessel floats. If a fault develops aboard a vessel that is not equipped with a transformer, the current could leave the vessel via a bonded/grounded through-hull fitting, shaft, or rudder, and travel through the water on its way back to its source. If a person enters that return path, a swimmer, diver, or someone who falls overboard while dockside, they could be electrocuted—it happens every year. Last Independence Day, in three separate incidents, five people were electrocuted on lakes in the United States in this manner. Make no mistake about it, swimming around boats or docks equipped with shorepower is dangerous; it is prohibited in many marinas with good reason. My advice to readers is don’t do it. Because both isolation and polarization transformers behave very much like a source of power, fault current seeks a path back to them rather than to the shore. This means that onboard faults will not result in current flow through the water. Current will return to the transformer, ideally tripping a circuit breaker and rendering the fault inert in the process, making transformer-equipped vessels inherently safer. Why wire a transformer in polarization rather than isolation mode, if the former requires the use of a galvanic isolator, whose effectiveness is limited? Essentially, there is a measure of added risk—the level of which is debated by experts within the world of marine electrical systems, in wiring a transformer in the isolation mode, in that the metallic case of the transformer is not referenced to both shore and dockside ground. Therefore, if the hot, primary, or shoreside input cable of the transformer were too chafe against the case, because the case is connected to the boatside ground, it could become energized without tripping a circuit breaker. (Remember, it can’t be connected to both boat and shore ground without creating a path for corrosion current.) If a person were to then touch the transformer case and a through-hull or rudder stock for instance, they could complete the path, and be electrocuted in the process. While this is a real concern, if an isolation transformer is properly installed in accordance with the manufacturer’s and ABYC’s guidelines, it will remain safe. Currently, transformers may be wired as isolation or polarization, and remain fully compliant. Among the most common defects in transformer installations are those involving a failure to use manufacturer-specified strain relief connectors for cables entering the transformer’s case. Under no circumstances should a transformer be wired without the benefit of proprietary strain relief devices, which prevent chafe as well as isolating tension or strain from electrical connections within the transformer. Finally, shorepower transformers used in marine applications should carry a UL Marine approval decal (many transformers are UL approved, few carry a UL Marine approval) as well as complying with ABYC E-11.17, last revised in 2012. Many older transformers carry an ABYC E-8 approval, which is outdated. If you have a shorepower transformer, or are considering having one installed, or are purchasing a vessel that is so equipped, make certain it is installed in full compliance with current ABYC guidelines.
Unregistered
Shocking!
závodník 'X'
^Same here and always around this stuff.
That link is outstanding and very well written. Since we're discussing lifts / shore stations, another is concerning capacity. And I'm not talking length. Years back had a friend tragically lose his life from a power winch assembly exploding apart. Fragment of metal entered his head. Airlifted to a hospital and later that night he slipped away. What initiated the accident was not so much the lift but he had a neighbors boat on it and was going to service it. Apparently the hull was filled with enough water and along with the boat weight to exceed limits of the lift. I don't know all the specifics or of that brand design, safety clutch / catch but luck was not on his side. Careful all.
“When these fine people came to me with an offer to make four movies for them, I immediately said ‘yes’ for one reason and one reason only… Netflix rhymes with ‘wet chicks,'” Sandler said in a prepared statement. “Let the streaming begin!” - Adam Sandler |
Information Junky
I thought for sure this thread would have a story about a 928.
(bump - good info)
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
WOW. News to me:
A lot of harbors have freshwater feeds and at low tide they can act more like freshwater-I could see the densities mixing like oil and water when the saltwater came back in. Since motors like pumps switch on and off there is really no way to check for this without access into or under the boat so I don't see any safe solutions. This is a common job for young kids around marinas and nobody I ever worked with, for, or any dive shop had any warnings up about this. It was good money but we all worked alone, quietly under the boat without even telling the marina we were there or they hassle you for not being a member and parking in the lot. This is a risk I never knew about and if this becomes wider known I can see it being banned (in water boat service) by marinas due to risk. |
We have a cabin on Lake of The Ozarks and this is a big deal down there. 4 people in the last year have died from this. The problem is for years and years there has been no inspections or any kind of oversight. Our dock is GFCI'd but hell it could be a dock 1/2 mile away and kill you. It's pretty scary. My family has had a place at the Lake since 1952 and it is scary how reckless people are on and around the water.
"Inside every old person is a young person saying WTF happened" If guns cause crime, all mine are defective. Ted Nugent 1983 911 SC 1978 Land Cruiser FJ40 2001 Tundra 1971 Datsun Fairlady Z RHD (240z) |
To give you an example of how back woods it it down there, if you are rebuilding a house using an existing foundation you don't need a permit and there are no inspections. It's unreal sometimes.
I live on a lake and have never heard of this. Scares the crap out of me.
I'm sure my wife has, she inspects the marinas.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
I see you
I live on a pond. I'm going to circulate this amongst my neighbors...just in case. Thanks Wayne!
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Information Junky
I'll add that this type of stuff can work to greatly accelerate corrosion of the metal bits on the boats.
I had a cousin that was electrocuted while fishing on a private pond. He was in an aluminum boat, barefooted, and reached up and touched a metal bridge that went over the pond. It had lights on it that weren't properly grounded. Needless to say it was very rough on my aunt and uncle and his sisters, to say nothing of the rest of the family.
So even on ponds you have to be careful if there's any kind of power nearby.
Scott '78 SC mit Sportomatic - Sold |
Dumb question: why is this an issue with freshwater and not saltwater?
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
The original article explains it very well in the paragraph right after the chart.
Yup - somehow I missed it
Silly question, but would a voltmeter be able to pickup the mAmp voltage ?
If not, why not ? |
