notfarnow's Avatar
Junkyard turbocharging
Last year I bought the twin to my first car, a 1984 Renault LeCar. Don't laugh, they're fun.
I got the basics sorted out last year, and was going to get it back on the road this summer, but now my SC is mostly back together so I'm not in a hotfired rush to deal with the Renault. I want to get it painted over the winter, and the clutch is toast so the engine/transmission needs to be pulled.
I'm really tempted to put together a ghetto fab turbo setup for a bit more beans, but don't know the best way to approach it. It has a Weber 32dir67 progressive carburator, and I already have it apart to be rebuilt. Before I do so, is there anything I should be considering if I want to turbocharge this car?
Also wondering if I'm better off to go draw-through or blow-through... my understanding is that draw-through is easier to set up. I also have a nice little k03 turbo off an old mk3 vw diesel I used to own
Not looking for maximum/best performance. Just looking to ake the car silly fun. Turbo lag won't bother me.
'03 Carrera 4s
+ a whole bunch of boats
Old 06-16-2016, 06:50 PM
weekend wOrrier
Just the idea of this thread is immediately more satisfying than the "new top gear"
Old 06-16-2016, 07:02 PM
Arizona_928's Avatar
eBay Chinese turbo parts lol
dolor et pavor
Copyright
Old 06-16-2016, 07:08 PM
LakeCleElum's Avatar
Dirt Cheep Blower......Put a generator in the trunk and power up the 110 Volts....
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 06-16-2016, 07:33 PM
Banned
I would not mess with a carb and a turbo
get a TB or a later cars MPFI set up and mega-squirt controler
or just a whole motor from a r-5
I would be tempted to move the motor to the back seat
but that has been done
Old 06-16-2016, 07:51 PM
Puny Bird
Mark Henry's Avatar
You can buy a FI system with basic harness for $500 shipped from Gotech out of south africa.
I believe it was 5000RSA plus 1000RSA shipping which converts to around $500.
They have a FB page, it's better than their website.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 06-16-2016, 08:52 PM
Following this, I know it'll be good. Please don't roast this one Jake!
Old 06-16-2016, 10:51 PM
canna change law physics
red-beard's Avatar
I'll bring the marshmallows!
James
Red-beard for President, 2020
Old 06-17-2016, 02:12 AM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
I think the F7R motor+5 speed out of the Clio 1.8 16 valve will fit your car and will give you 130BHP straight out the box. Cheap as chips to buy that power train from a European wrecker.
Suggest Renparts in Doncaster UK as your starting point, and they will likely know if I am correct in my suggestion.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 06-17-2016, 04:28 AM
This. FI + Turbo.
Old 06-17-2016, 05:13 AM
notfarnow's Avatar
I like this car enough to scab together an exhaust system to a used turbo and pump/pull it through the carb. Not sure I like the car enough to convert it to FI.
This car is already mid engined, technically. Just fwd, mid engined.
'03 Carrera 4s
Old 06-17-2016, 08:36 AM
DanielDudley's Avatar
Yes, if you box in the carb, it doesn't really matter if there is a little leakage. Easier to pressurize the whole assembly than to try to force it all into the inlet. A couple of PSI at low RPMs could do wonders...
Old 06-17-2016, 02:55 PM
notfarnow's Avatar
I just noticed these... lol, ba$tards. I actually had this car catch fire on me briefly in the fall but I was able to deal with it quickly. That whole thing everyone says about replacing furl lines in old cars.... not such a bad ideer
'03 Carrera 4s
Old 06-17-2016, 06:27 PM
red-beard's Avatar
Oh no, not again!
It's better to burn out, than to fade away
James
Old 06-17-2016, 06:45 PM
Get an AMR 500 and supercharge it?
Old 06-18-2016, 12:10 AM
least common denominator
scottmandue's Avatar
Pics or it didn't happen!
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 06-18-2016, 08:09 AM
notfarnow's Avatar
How about pics AND it didn't happen?
Notice my 3 bolt mags... OH YEAH
I have the carb apart and have a rebuild kit... it was FILTHY inside. No wonder I couldn't keep it running properly.
I'm not in a huge rush to get it running again right away, because I want to explore this option while it's apart.
So basically just seal up the inlet and feed the carb as-is? No need to modify anything in the carb to make it run under pressure? Again, I am fine with it being a compromise as long as it can be made to run. I have a spare engine, so I don't mind blowing one up if it's fun enough
'03 Carrera 4s
Old 06-18-2016, 08:42 AM
red-beard's Avatar
What? No that will not work. The carb works by volumetric flow. If you increase the pressure (air density) you will not get enough fuel for the same volume and will run lean. With Fuel Injection, there is usually a MAP sensor and it will adjust the fuel flow with the air density.
James
Old 06-18-2016, 09:14 AM
To be fair.... I had a small fire on the bug, but I was able to get it out. Should have let it burn! Was insured for more than I sold it for. But it was in the garage at the time!
Old 06-18-2016, 04:57 PM
