Checked out
Simple trick to pass smog check?
I was thinking this morning - wouldn't this be a very easy mod that would pretty much ensure that any car would pass a smog check?
(I'm not suggesting doing this, it may or may not be legal, just curious if it would work) 1) Weld in a bung (like an oxygen sensor bung) in the exhaust system somewhere. Maybe right before the muffler. 2) In normal use, just have it plugged with a bolt. But for a smog test, hook up a hose to it, hooked up to a high volume electric fresh air pump. It would seem that any fresh air pumped into the exhaust flow would pretty much reduce NOX and CO2 on a 1:1 basis, i.e., if the exhaust flows at 350 CFM and you "inject" fresh air at 350 CFM you'd cut down measured emissions in half. Would it work?
The Unsettler
Easier.
Drive car till near empty. Do a tune up, fresh plugs and filters. Dump a few bottles of gas line antifreeze in. The stuff is pretty much pure alcohol. Get smogged. Fill with gas. I used to do that with my Starion. Worked every time. Saved me from the yearly cat bypass swap out.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Checked out
Interesting. I wonder if the reduction could be calculated. I.e., if you dilute the gas by 10%, you get a 10% reduction in NOX and CO2.
Detached Member
Don't think so, the machine looks for a certain amount of oxygen so it knows the tester is not cheating by not inserting the probe entirely.
Hugh |
stomachmonkey has the answer.
Instead of gas line antifreeze, you can use pure methanol I also add a couple of oz. of acetone. To a tank w only 3-4 gallons of gas. Be sure to fill tank ASAP after doing this. No law against putting your own 'additive mix' (a.k.a. homebrewed Techron) in your car. . . . or is there?
_______________________________________________ 45 yr addiction 1965 356 Coupe, '70 914- POS, '74 911- lightweightFUN, '83 SC Cab- 100%AnalogOpenTop. |
Careful with putting methanol in your gas tank. From another site:
Methanol is very corrosive to the fuel system components when compared to gasoline. Steel, aluminum, pot metal, and soft materials in the fuel systems can be attacked by Methanol. Also, someone made a comment on a Rennlist about water /methanol spray to cool intake temperatures. While a different scenario than in the fuel Steve Weiner responded this way: "Methanol attacks the Nikasil plating in the bores of the cylinders so I would caution anyone from doing that".
Kurt |
Isn't this essentially what Porsche did with the 930? I removed mine when I had my engine out, as have most owners I would assume. It had an fresh air pump and injectors that were in the exhaust port of the cylinder head, remove the pump and injectors and plug the open port in the head. They did not make a cleaner engine, they just diluted the exhaust.
Air pump removal???? |
Information Junky
eh-ehm.. with EFI, if one of the injector leads accidently pops off that cylinder becomes an air pump.
So you want to make sure nothing like that happens or it will false the sniffers.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
With my 2007 Chevy, the smog shop just plugs in the ODB2 reader that looks deeeeep inside the car's computer to see what is happening. No rolling test at all, not sensor up the butt, ETC.
Emissions testing is such a joke .
No left turn un stoned |
Dog-faced pony soldier
It isn't about emissions anyway. It's all about money.
Driver
I wonder how much greenhouse gas is expelled by emissions testing. Not just from the cars running on the rollers, but also by the pre-test warming up that gets done (whether by the owner or the tech).
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
In Ca any 2000 and newer car now just get plugged into the ODB port for Smog tests. Visual check and gas cap check still apply.
J Mac Current 0 Sold - 67 911T Coupe racecar, 87 911 Cabriolet, 85 911 Targa, 98 Boxster, 95 993 Coupe, 88 911 Cabriolet, 75 911 Carrera #144, modified |
So what you are saying is that there is a market for a fake OBD port with a mini-computer behind it that can receive signals and spit out the correct responses....
Mighty Meatlocker Turbo
Moth balls in the air cleaner usta work years ago on a 1976 Buick I owned in New Jersey. No testing of any kind here in Kentucky for several years now. No safety inspections either. That part of it sucks. Lotsa unsafe junk on the roads along with bad drivers.
Edgar 1984 Porsche 944 bone stock 1995 Mercedes E320 wagon 1970 Honda CB350 mint!!! |
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Not here. At least not on catalyst-equipped car. Here in EU, sniff test is usually done by four-gas machine. Just piping in fresh air might help burn some CO, but lambda (and probably NOx) would be through the roof. Basically they insert the probe into exhaust pipe, which measures CO, CO2, HC and O2 in real time. If mixture is stochiometric and catalyst works, HC, O2 and CO will be low. Why would you want to do such thing (remove lambda sensor) in the first place? Car are programmed to run rich at WOT anyway, so you wouldn't gain any power.
Thank you for your time, |
Only on the very early, USA models that had thermal reactors - the rest, including 1986-1989 USA models, and ROW, were as I described. And the air injectors are placed in the cylinder head exhaust ports on all of them.
