scotricker's Avatar
Wiring Relay for my Garage Ventilation Fan?
I put a vent fan in my garage that I want to turn on with the garage door opener and stay on for as long as the light is lit. So I thought I'd just tap into the light socket wires and connect to my fan,,, But that might be too much load for that circuit board.
I need to find a relay, and I looked on ebay, but don't know what I'm looking at.
So if I have 110 volt going in to activate the relay, and 110 volt going in as supply, then 110 volt going out to fan. Sounds simple to me, but I just don't know which relay will work. Any advice or ideas? Thanks,
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 09-18-2016, 07:49 PM
RETIRED
Joe Bob's Avatar
How many amps is the breaker rated at? How much does the fan pull? You may be overthinking this....
2012 ML350 3.0 Turbo Diesel
Old 09-19-2016, 12:39 AM
DanielDudley's Avatar
https://www.amazon.com/Packard-C230B-Pole-Contactor-Volt/dp/B001KGSJ74/ref=pd_sim_328_1?ie=UTF8&psc=1&refRID=4WPWAA5EN3TAGJKXD2BW
This is rated for 30 amps, but use a 15 amp breaker.
Old 09-19-2016, 12:57 AM
scotricker's Avatar
Perfect. Thanks. that will do it .
Scot
Old 09-19-2016, 04:27 AM
scotricker's Avatar
Oops, wait.... Now what if the fan is already on running when I hit the garage door opener?
Like for the summer, I want to put a temperature sensor switch thermostat.
So, if the fan is already on, from another switched source, and then the garage door circuit turns on too, will there be too much voltage? or will the fan only use what it needs? Or do I need a different, or additional relay?
I know this is turning into a science project, but it might be fun.
Scot
Old 09-19-2016, 05:34 AM
Thermostat pulls in one relay, opener pulls in the other relay. The contacts from either relay run the fan.
Personally I would put it on a timer.
Old 09-19-2016, 08:14 AM
Super Moderator
cstreit's Avatar
Why not just get one of the temp/humidity operated fans? Are you hoping to vent exhaust gasses or something? I doubt the 5 minutes your garage light is on will be sufficient time to exchange the air.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 09-19-2016, 10:32 AM
T77911S's Avatar
run 120 off the garage door opener to a small relay.
get a 24v transformer
put your Tstat on a low voltage transformer.
run 24v to both contacts of the 2 transformers then to the contactor for the fan.
(the contacts of the relays will be in parallel)
now both relays can be energized at the same time.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-19-2016, 10:57 AM
canna change law physics
red-beard's Avatar
What is the power consumption of the fan?
James
Red-beard for President, 2020
Old 09-19-2016, 02:50 PM
Can you share what fan you plan on using?
1982 911 Targa, 3.0L ROW with Webers
Old 09-19-2016, 03:02 PM
scotricker's Avatar
This one. It's already installed. Does a good job !
Master Flow 1250 CFM Power Roof Mount Vent in Weatherwood-PR2DWW - The Home Depot
Scot
Old 09-20-2016, 06:43 PM
red-beard's Avatar
It is 1/6 hp. 230 Watts
James
Old 09-21-2016, 03:23 AM
UnRegistered User
billybek's Avatar
Sounds like what you want is a switch to sense when the garage door is open and have a period of run time after it is closed.
Sounds like you would also like a switch in the space to cycle the fan.
Example micro switch
https://www.amazon.com/Uxcell-a11021800ux0120-Switch-Straight-Action/dp/B0050HKB8O/ref=pd_lpo_328_lp_img_4?ie=UTF8&psc=1&refRID=Y7GAGDYT9KRCEGMV66AB
A small multi purpose relay would handle that load easily.
Relay 110/120 VAC Coil Voltage PR341 Mars Relay 90341 [PR341]
If you want it to remain on for a period of time after the door closes, an inexpensive delay on break relay would keep the fan energized for a given amount of time.
Delay on Break Timer Time Delay Relays - Littelfuse
The end switch on the door and the wall switch would be wired in parallel to energize the delay on break timer. The delay on break timer would then energize the fan relay to start your ventilation fan.
Components for this would be available at any HVAC parts store.
Bill K.
Old 09-21-2016, 04:11 AM
scotricker's Avatar
Thanks for all the good ideas !
Scot
Old 09-21-2016, 04:40 AM
