Discseven's Avatar
Need help with Arduino code for digital AC config
EDIT: John is in.
Am putting together Arduino components to sense temp & humidity and to serve as a thermostatic controller for 911 AC system.* Collected data will be fed to a 4x20 LCD. "Set Temp" will be controlled by a potentiometer with temp target displayed on LCD.
Hardware for this I can handle. Am looking for an Arduino sketch expert to help with the code.
* System: 2 temp & humidity sensors, 2 temp sensors, 1 Arduino Uno, 1 4x20 LCD, resistors and potentiometers as required.
Collected sensor data:
Cabin temp
Cabin humidity
Evaporator core temp
Duct temp
Exterior ambient
Exterior humidity
Set:
Target temp (with some hysteresis)
7 data points will be displayed: 2 items per line on 4x20 LCD. "Set Temp" on top line by itself.
If/Then = IF "Cabin temp" is =>2 degrees F compared to "Set Temp", THEN compressor & fan circuit is closed (AC is ON.) If "Cabin temp" =< "Set Temp"< THEN compressor & fan circuit is open (AC is OFF.)
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 09-25-2016, 06:52 AM
