My total knee replacement- no trouble
Thought I'd report on my knee replacement on 3/08/16.
I heard of many painful replacements from buddies, so I was very unsure about this whole deal.
Briefly, I report that it was no great big deal as far as pain & discomfort. I was given a full compliment of pain meds (hydrocodone & tramadol). I used only 1 or 2 following the replacement. I just didn't need them. The recouperation was the biggest difficulty. It took about 4 or 5 weeks before I could walk w/out any type of assistance.
Without a doubt it was a good thing to do. Should have done it years ago.
Old 09-28-2016, 01:01 PM
Unregistered
sammyg2's Avatar
Did you ever have surgery for a torn meniscus on that knee in the past?
Old 09-28-2016, 01:48 PM
I did, about 30 +/- yrs ago. And?
Old 09-28-2016, 03:03 PM
Slackerous Maximus
HardDrive's Avatar
Mom had it done. Recovered quickly and knee works great. Amazing time we live in.
2014 Cayman S, PDK
Old 09-28-2016, 03:16 PM
I had meniscus surgery about 10 years ago and now my knee is swollen and aches all the time. I guess knee replacement is in my future.
Old 09-28-2016, 06:14 PM
id10t's Avatar
I've been thru hundreds of them working as a PT aide in a hospital.
If you are a fat little old lady, start doing exercises *before* your procedure
After the procedure, wear the damn knee bending machine. And let it bend. And bend some more.
Do everything your physical therapist tells you. If you don't hate their guts after the first 2 sessions then one of y'all is slackin off.
Walk. Do your damn exercises. Walk more.
Old 09-28-2016, 09:13 PM
DanielDudley's Avatar
They seem to have gotten this down, and the new designs for replacement knees are really superior to the old ones, principally in how they attach to the bone.
Every one I know who has had this done says they wish they hadn't waited. Glad you are doing well
Old 09-29-2016, 03:47 AM
Ah, the healing touch.
Old 09-29-2016, 03:49 AM
JavaBrewer's Avatar
Does this also apply to shoulder replacements? I have less than 20% mobility in my left shoulder for almost 5 years now. Many times dislocated, broken 2x, there is nothing left to mend. Advanced arthritis and constant pain. Two consults say replacement is only fix. The thought of replacement worries me enough to just frown and bare it as is.
Old 09-29-2016, 06:24 AM
Do be carefull about waiting too long on the shoulder.
A buddy waited till he absolutely had to go for replacement.
Waiting too long meant the the procedure was much more complicated with more deterioration in the bone that received the replacement parts.
It is great that these repairs are available.
Cheers Richard
Old 09-29-2016, 06:36 AM
Unregistered
sammyg2's Avatar
The reason I asked was that I also had meniscus surgery, and was told after that it often leads to total knee replacement later in life.
Just gathering anecdotal evidence.
Old 09-29-2016, 06:37 AM
FUSHIGI
As meniscus or joint space structures become inflamed, damaged and/or deteriorate over time, the cartilage covering the ends of bones is forced to take more and more of the pounding. It's not good at doing that and when the cartilage is sufficiently damaged or worn away (leaving bone on bone), pain brings people to the surgeon.
Each joint's approach for replacement is different but the pain generating cartilage is sawed off and replaced with polished metal that is glued or otherwise incorporated into the native bone. Knees and hips obviously support a lot of body weight so the metal bone ends are separated by plastic spacers. Less well known is that arthritic toe and finger joints are also routinely addressed today.
As stated earlier, it's not uncommon to hate/fear your physical terrorist. However, PT's see a lot of people after surgery and if unbiased, can serve as a great guide when choosing an orthopedic surgeon because they see the outcomes and should be able to spot patterns.
People tend to find elective procedure surgeons using their feelings. Don't. Do your homework then pick a surgeon. The highest volume or nicest surgeons aren't always your best choice.
Old 09-29-2016, 07:50 AM
tops911's Avatar
Javabrewer, I had a shoulder replacement 3 months ago, I'm 54. I think I have more mobility now than before the surgery. I was really torn over whether or not to get the replacement; but I'll be leaving the Army soon and decided to get it while I'm still "important" (active duty). Part of what convinced me to do the replacement was that the longer one waits the more muscle loss one has, less mobility, and all that makes the recovery harder. I'm a little disappointed with the PT I've received it has not been challenging to me. I expected someone moving my arm around, but i just do exersizes at home on my own and go to the hospital once or twice a week if they have room. I'm told by the 6 month mark I'll know what the real results will be. 3 months after the surgery i think it was worth it.
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 09-29-2016, 08:11 AM
Unregistered
sammyg2's Avatar
15 years ago:
Old 09-29-2016, 08:25 AM
IROC's Avatar
OK, so I have "total knee replacement" in my future according to the orthopedic surgeon that looked at my x-rays. I have some pain, but it is easily manageable at this point. I did have to stop running, etc.
My question is that I'm only 52. How many miles do you get out of a new set of knees? I assume this is a one-time surgery? Do I need to wait until the last minute to go through this to maximize the mileage I get out of them?
Things I've wondered about...
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 09-29-2016, 08:42 AM
FUSHIGI
While these are questions for your surgeon, a fair bit of it comes down to luck, body weight (and/or mileage) and proper installation. At one time, I believe 10-15 years was a commonly quoted average but that may have grown.
As for when to have it done, that decision frequently lends itself to a pain vs quality of life equation. As evidenced in this thread, most people do well after their joint replacements. Naturally the younger you are when having new parts put in, the more likely it is that you will need your surgery revised at some point.
Lastly, 52 is young. If you're doing well, I'd definitely wait but balance that against your health now (good health is positively correlated with tolerating the procedure and recovery well) vs your health n years into the future.
Old 09-29-2016, 10:47 AM
IROC's Avatar
Thanks for the response. I'm not sure why my knees are worn out, but years of sports and recreational running (5Ks, etc.) evidently took their toll. Not massively overweight (6' 3", 215 lbs) either. My plan is to try and make it as long as I can. I just worry that every time I climb a flight of stairs or play in the backyard with my kids, I am taking some "life" out of my knees...
Mike
1976 Euro 911
Old 09-29-2016, 10:56 AM
FUSHIGI
Everything takes its toll but that's the price of living!!
Old 09-29-2016, 11:20 AM
A little over a year ago. I was at the ortho just today; he tells me I could use a new knee, but I'm too young.
Old 09-29-2016, 06:57 PM
least common denominator
scottmandue's Avatar
My mom has had a shoulder replacement and hasn't had much trouble... however she is now 92 and had it done in her late 80's so it is not like she is out playing racquetball.
She has had both hips replaced and one has dislocated several times... however at her age it may be due to her forgetting to follow doctors orders.
I should add IMHO definitely get it done sooner rather than later... a lady friend put it off... put on a lot of weight because she became less active... then Dr.'s couldn't operate because she was obese... she got on pain meds and... well... it was the end of her.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 09-29-2016, 07:22 PM
