fastfredracing's Avatar
Popping out a gas tank dent, any tricks ?
Finally grabbed up a dual sport . Got an 1989 Yamaha xt 350 with a broken piston. Gonna be a little winter project for me . So, it has a steel tank ,and of course , there is a nice sized dent right in the side.
Any good tricks? The dent is in a place that I cannot really get good access from inside the tank, so I cannot really bang it out that way .
I guess I can flush the life out of the tank and use a stud gun dent puller if I have to , but I would rather not . Fill with water and freeze? Suction cups ?
I am sure I could google it , but you guys are more fun .
No left turn un stoned
Old 10-10-2016, 06:11 PM
Congrats on your new scooter, Fred!
I wonder if it would make sense to buy a new tank...either used or after market?
If yours could be fixed, someone here would know.
Can you post a couple pics?
Old 10-10-2016, 06:30 PM
id10t's Avatar
Drain all but a little gas from it, drop a match in ...
Burn the fire.
Brando's Avatar
Get one of these!
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 10-10-2016, 06:38 PM
Functionista
manbridge 74's Avatar
Seal it and use air was the old technique.....
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 10-10-2016, 07:52 PM
Ubi bene ibi patria
Hawkeye's-911T's Avatar
^^ Bloody scary - that technique - if you ask me. Make sure to take all the necessary precautions because the potential of bad $chitt happening with any pneumatic testing or process.
Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 10-11-2016, 11:00 AM
Don Ro's Avatar
Cheers
JB
If you're referring to the T-Hotbox above, I think it's done with heat.
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 10-11-2016, 11:55 AM
Cheers
JB
It should be 99% water, 1% air...
Old 10-11-2016, 12:12 PM
What about the hot glue packages? They are cheap on Amazon.
Old 10-11-2016, 12:13 PM
I just did it this morning on a Unimog tank that was dented on the bottom pretty good, Just blocked off all the ports and put the air to it. Popped out all dents and looks as good as new!
Von
http://vonsmog.com
73' 911T Coupe, 76' 911S Targa
73'& 80' Mercedes Unimog DoKa
59' Austin Healey 100-6
Old 10-11-2016, 12:14 PM
Don Ro's Avatar
Lots of YouTube vids showing success.
I've got a slight tank dent in my '75 Yam. DT400 that I need to address.
I may try this method first.
Don
Old 10-11-2016, 02:12 PM
Depending on how big, where it is, and how badly the metal has stretched....
Heat with blowtorch. Good and hot.
Ice water.
Used to do with to remove dents from armor all the time.
Of course, you'll have to repaint.
Powerful suction cup maybe. I've managed to pull out a couple using one.
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 10-11-2016, 03:02 PM
LakeCleElum's Avatar
I ruined a good tank once using air pressure....The bottom of both side bowed away from the frame.....Looked like the Droppy ears on an old Hound Dog...
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 10-11-2016, 04:35 PM
wayner's Avatar
You don't need much pressure
Put a bit in and use a hammer to gently tap around the edges of the dent
SOLD - 914 wide body hot rod
Old 10-11-2016, 05:04 PM
Tim Hancock posted pics working out a dent one time. Pm him!
Old 10-11-2016, 08:06 PM
Don Ro's Avatar
New Project! CB450 soon to be a cafe racer!
Don
Old 10-11-2016, 08:22 PM
You do not have permissi
john70t's Avatar
Use them all at once ?:
-Metal straps or vice to contain and maintain everything.
-Internal pressure.
-External pull studs.
-Heating everything with spot cooling center to quick shrink (nitrogen dry ice?).
-Tapping edges (but metal is stretched and weak there).
-Pushing from inside like PDR.
Old 10-11-2016, 08:23 PM
