canna change law physics
The $10 transformer protected the $0.10 fuse
Yep, someone who worked on my furnace installed a 5 amp fuse instead of a 3 amp fuse. The 40VA 120VAC to 24VAC transformer died, protecting the 5 Amp fuse.
The thermostat has an extra 24VAC neutral wire, which should not be hooked up into the newer style thermostats. Of course, I hooked it up... Worked fine with the Air Conditioning, but when I switched the system to heating, it quit working. One furnace, the 3 Amp fuse blew, the other had a 5 Amp fuse and the transformer died. At least it was only $10. And we didn't really need heat much this weekend.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
