RETIRED
Looking for under dash rocker panel, blank....
Cant't seem to find a source for blank panels for 3/4 inch round hole rocker switches for accessories. Extra lights inside the engine bay and interior. After my Lasik, low light acuity is not good. So I am going to install a couple extra LEDs to help an old man (yes, me).....I have the switches.
I could fab something up with thin sheet metal but a pre made panel would be preferable. 2-3 holes or 4-6 that I could cut in half. ![]() They would hang under the dash. Any ideas or links appreciated.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Control Group
RV or marine shop should have something like that
She was the kindest person I ever met |
RETIRED
Thought of the marine stores...nada. RV, good idea....
Super Moderator
As mentioned, marine supply or check out longacre racing
Control Group
What about the guy here that does resto work on switches? I bet he has some gear like that. Shipping would be pricey though, he is in Poland or something.
You'd have to enlarge the holes - maybe 1 of these would work. (Horrible Freight carries an inexpensive bit for sheet metal hole enlarging that would do the trick.)
Rack Panels with pre-punched holes - Full Compass
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Pretty popular in the Jeep world, might try looking at some of there web sites
"Inside every old person is a young person saying WTF happened" If guns cause crime, all mine are defective. Ted Nugent 1983 911 SC 1978 Land Cruiser FJ40 2001 Tundra 1971 Datsun Fairlady Z RHD (240z) |
There are holes in the dash for factory style switches, and they use smaller holes. I wouldn't install under dash switches on a 911 because the dash is already so low. You might try a pull switch, or a 3 position pull switch maybe, in the dash?
RETIRED
Found what I needed, thanks.
RETIRED
Aluminum angle "iron", Sawzall and Dremel and SEM Trim Black. No one had anything I needed. $0 as I made it out of scrap.....
