Kantry Member
oldE's Avatar
And that's why oil coolers and transmission coolers and differential coolers exist.
A lot of the extra hp gets wasted as friction. More power, more friction losses.
Best
Les
Best
Les
Old 12-19-2016, 04:08 AM
DanielDudley's Avatar
Maybe we should, for the purposes of discussion, assume that the losses are 15% at max power, which is the only part of the equation that ever gets addressed.
Perhaps they are less when running at 10% power, and perhaps they are more. Most people are only interested in what total HP numbers they can infer at max output.
Of course a lot of guys only quote wheel horsepower for accuracy. but I am still going to say that drive train losses are related to load on the system, and they would be much less in a no load situation, and much more reflective of what you are saying. If we are talking about a 75 HP loss at 4 or 500 HP, I can only say that that must reflect real world conditions, as engine builders and dyno operators always seem to quote the same loss figures. FWIW, they quote higher figures for AWD vehicles and fuel economy also drops, so I expect the losses are real, whether it has to do with friction or inertial losses or whatever.
They say it is mathematically impossible for bumble bees to fly, but they do anyway, so it must be real. Driveline losses at WOT are the same, for whatever the cause.
Old 12-19-2016, 04:16 AM
Platinum Member
dad911's Avatar
Originally Posted by afterburn 549 View Post
Nah...I see what you are saying...but,...nah
Jump from 100 HP to 200 HP .
There will be no added 10 hp added loss.
SEE?
That's what I am saying....these arbitrary numbers floating around....
Just changing HP can not cause more drag.
Simplify. Remember High School Physics? u= coefficient of friction. It was always expressed as a fraction or decimal, same as a percentage, and was constant. f=uF.
Logically, think of resistance in the gearbox as friction. Friction causes gearbox/fluids to heat up. More heat, more loss. If you put 10HP on a 915 gearbox, it will likely barely raise the temps. 500HP and it will get hot, cook fluid, and self-destruct. So yes, % loss may be similar, but with more HP there will be more (frictional)Loss, as noted in raised temps.
Old 12-19-2016, 07:56 AM
Still Doin Time
asphaltgambler's Avatar
I'll chime in. I think for simplicity sake, I see it as this. Take an engine that makes 100 HP @ the crank. It is coupled to a conventional rear wheel drive setup sans vehicle for this discussion. If measured at the drive wheels the loss might be10% / 10 HP.
Now take the same engine which makes a verified 200 HP @ the crank, bolt to to the same existing drive train connected to the wheel dyno. Assuming the trans/ diff would tolerate a smooth application of twice the power - I don't believe, as a matter of fact some one would have to prove this in real world testing, we'd see the same % of loss.
Now in actual on the road testing, the same drive train rated for 100 HP would most likely fail at some point with shock loading, torque. I'm sure the friction would increase but I don't see how it would double prior to failure.
Old 12-19-2016, 08:11 AM
Air Medal or two
afterburn 549's Avatar
And thats my point..too.
It does not seem logical.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 12-19-2016, 08:13 AM
Information Junky
island911's Avatar
Search "gear friction loss as a function of load"
The first hit is http://www.geartechnology.com/issues/0905x/mba.pdf
Looks legit. Should be useful.
Old 12-19-2016, 08:14 AM
Drive train losses are a function of the load in the transmission, the normal force between the gear teeth increase at higher loads, and the friction loads at that interface are roughly proportional. Their are fixed losses as well which dont scale with speed.
Applying a gross percentage as an estimate of drive train losses is a rule of thumb at best, and for entertainment purposes at worst. There are 100 million related discussions on the internet. Nobody uses that number in the engineering context. The good thing for car dynos is that torque/power at the wheels is what matters for car performance, so the crank hp is just a curiosity anyways. If you really need to know it, better grab your wrenches and book an engine dyno
18 Cayman GTS
Old 12-19-2016, 08:21 AM
White and Nerdy
Tervuren's Avatar
It is indeed a lot of loss, that is why F1 cars can't follow at distances of much closer than 60 feet for one or two laps, before the driver has to back off. Before the current electric Hybrid's F1, you'd hear radio communication if a driver didn't get a pass done in a lap or two, to back off, and let the transmission cool.
If you ever get the chance to see a fully assembled NASCAR, the amount of cooling systems they have is amazing.
The ducts on the upper rear fenders of the current Gen Corvette, feed dual radiators for the rear mounted gearbox and differential.
Shadilay.
Old 12-19-2016, 08:45 AM
This. ^^^^ The difference between load losses and internal losses.
That's all you need to know. Your intuition is correct, not accounting for load.
Old 12-19-2016, 02:37 PM
You do not have permissi
john70t's Avatar
http://www.mdpi.com/2075-4442/1/4/95/pdf
I thought Carbon60 was going to become the next miracle oil. https://en.wikipedia.org/wiki/Fullerene
It does prevent wear at high load, but no corrosion inhibitors, and not for Nikasil/Alusil.
Nanodiamonds polish surfaces well, but also cylinders.
Boric acid doesn't mix with some lubes or replace ZDDP.
PTFE clogs everything up.
Old 12-19-2016, 06:17 PM
Originally Posted by unclebilly View Post
Why do high performance cars need a tranny cooler whereas commuter cars do not? Assuming both have the same parasitic losses in the trans...
Originally Posted by Tervuren View Post
As force is increased, so is friction.
Think of sliding a 200lb object across ice, now try sliding a 400lb object across the ice. Even if you have the object on a low friction surface, the 400lb object will have more drag on the ground.
Those two ^ together totally did it for me. I've often wondered. Assuming you have the same car, so a theoretical Veyron, and the "valet" key knocks the motor down to 100hp, so the frictional loss (15%) is 15hp, but then the owner gets in and has the full 1000hp, so 150hp loss. Yeah, sounds crazy and extreme, but it makes sense now. Granted, I'm assuming these are as stated, guidelines, and the graphs aren't a straight line, but still, pretty cool that I can visualize it now.
SEE?
Yep.
Dragging a large steel cube over a large, lubricated steel sheet (MD Holloway is there). Together, the coefficient of friction is of steel on steel with lube is .16.
Ff = μ m g
First, a 100lb cube of steel.
Ff = .16 * 100lb = 16lb
Now, lets double the weight of the cube.
Ff = .16 * 200lb = 32lb
This is like doubling the horsepower, except I assume we would really be talking about the torque.
So the friction of 2 gears on each other with twice as much force applied would be double (you know, assuming very general, ideal type circumstances).
Old 12-19-2016, 06:40 PM
Losses might be 10% or they may be more or less. The SAE has concluded that every drivetrain is different and assuming arbitrary % loss is not accurate.
In real life drivers have to let their 500 hp engines loaf along (for traffic or whatever) most of the time. Drivetrain loss is a function of the power the engine is actually producing at any given time, not it's potential. Doubling the HP capacity of the engine won't materially affect transmission losses if you maintain the same driving style. Is that what you mean?
So, The guy in the Veyron with 1000hp at 35 mph is seeing the same losses as the guy with a Veyron using the valet key so he only has 100hp. Where their losses would be different (150hp vs 15hp assuming 15% loss) is if they were full throttle at the RPM where they are each making peak power.
Old 12-19-2016, 06:43 PM
First - I said I was dense .
I never said you, or anyone else in the topic is /was.
It is truly quite EZ to repeat what we have been told.
I can do that too.
Which again is why I drool along here.......
I do understand that number thrown out for drive train loss is the 15% number.
I was using the 10%number for simplicity, as stated.
My argument (again) is-
Using the 100 hp @ crankshaft figure, it is expected to see 85HP at the wheels, if we insist on using the 15% rule.
Now we pump up the engine to 200 HP it is said we lose15% which will now equal 170 HP , linear, with 30 HP loss.
To me, going linear up the scale, -it gets ridiculous.
A 500 hp will now see 425 @ the rear. with 75 HP missing in losses.
So with the 100 HP we lose 15HP
At 500, we see 425, 75 HP now consumed in the mass somewhere.
That is one HUGE number to eat!
Stuff is going to be glowing red RED HOT right now.
Yeah, following your reason, this makes sense, but you also have to think about, the transmission for a 52hp Chevy chevette is probably, much, much smaller and lighter than the transmission for a 500hp Corvette, even if they were both 4 speeds. And when they take something like a corvette, the standard model has a tranny, but the Z06 model adds a tranny cooler. Some cars have added finned diff covers.
Some trannies will have more fluid, bigger, heavier gears which will withstand the power AND the heat better, or maybe more gears which add more mass to absorb the additional heat. Besides, I'm sure there are things that are calculated by the engineers like "Is the average corvette owner going to be at peak output all of the time or only for a few secs here and there most of the time. Do you think that the Corvettes at Le Mans use the same tranny with no additional cooling as a street 'vette. No, of course not, they use at least a cooler if not a different trans. And that's because they are always forcing max power through the trans. Since most vette owners are probably mostly loafing around at 1500 rpm using a tiny fraction of the power on tap, they aren't creating the heat or experiencing those losses
Old 12-19-2016, 06:55 PM
