-   -   If I Need Any Welding Done (http://forums.pelicanparts.com/off-topic-discussions/941657-if-i-need-any-welding-done.html)
wdfifteen 01-08-2017 07:19 PM
Originally Posted by 1990C4S (Post 9423769)
Where I work you would have to grind out and repair that slag inclusion/void in the start...but I doubt you will die if you don't.
When I mig welded trailers together for a living, welds that looked like that one apparently does (its just one view in a picture) were discouraged and sometimes outright rejected. I had to keep the heat closer to the elements to be joined and use less fill for such a weld. But I only had one boss and only had one welding job, so what do I know. It may just have been him.
1990C4S 01-09-2017 05:22 AM
Originally Posted by Shaun @ Tru6 (Post 9423793)
Do you know why it did that? What happened there? Only one of the 4.
Cleanliness, and I think sometimes it's from the mig wire.
They can't be can't be completely avoided, but in some applications they are stress points that lead to cracking and have to be removed.
Don Ro 01-09-2017 06:42 AM
http://forums.pelicanparts.com/uploa...1483972927.jpg
