Don Ro's Avatar
Ultrasonic Cleaning Agent - What Do You Use?
Picked up a cleaner yesterday and the reviews on Harbor Freight's cleaning agent are not that great...some say that they use Simple Green, others say hot water and dish soap, etc.
I'm cleaning a couple of hand guns...what do y'all use?
TIA.
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 02-03-2017, 11:13 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Dawn
Who Will Live... Will See
Old 02-03-2017, 11:41 AM
Vaccinated and Boosted
mgatepi's Avatar
A drop or two of Damn
2013 911 Turbo S
2025 Lexus TX350, 2024 Honda CRV Hybrid
1930 Cadillac V8, 1991 Ford F250,
2023 Chevy Colorado
And some garage space....
Old 02-03-2017, 12:04 PM
Don Ro's Avatar
Thanks gents.
2.5 liter bucket, only a drop or two of Dawn? That's not much.
Ought it be hot water?
And after rinsing, put it back in the unit w/clean water to rinse even more?
Don
Old 02-03-2017, 12:54 PM
Depends on what you are cleaning. I used have one to do heavy degreasing/cleaning, and have had great success with Pine Sol. It is cheap, and worked great. The machine heats it IIRC...
Old 02-03-2017, 01:42 PM
JJ 911SC's Avatar
from: Ultrasonic Cleaning question - what "solution" do they/you use?
Ultrasonic cleaning works best when the surface tension of the water is reduced. 2 common methods are (1) detergent and(2) heat to reduce the surface tension. I bought 4 ultrasonics for Corning when I was their process engineer. They work by creating millions of microscopic air bubbles that explode in the water to scrub. A common way of testing the power of the action is to leave a sheet of aluminum foil in the bath for 30 seconds and seeing how much the foil is worn. Test your soaps solutions or heat this way to see which works best. Don't put your hands in the ultrasonic because it ruptures your cells. A few drops of detergent per gallon of water should work fine. There are different ultrasonic wave lengths used by different manufacturers. The really nice ones use a sweeping wave length that incorporates a few different wavelengths throughout the cleaning cycle. You could make your own ultrasonic cleaner by just buying the transducers and power supply and attaching them to the bottom of a stainless steel pan. You can file this comment under " More than anyone needs to know about ultrasonic cleaning ".
Old 02-03-2017, 01:47 PM
unsafe at any speed
wswartzwel's Avatar
I use a 50/50 mixture of pinesol and simple green.... Fill my machine 25% with that and 75% water. works great at 140 degrees for cleaning gunky carburetors.
Bill Swartzwelder
Old 02-03-2017, 01:51 PM
MBAtarga's Avatar
Be careful when cleaning aluminum and alloys - some of the cleaners that you would consider mild will eat the metals.
Mark
'83 SC Targa - since 5/5/2001
Old 02-03-2017, 03:06 PM
Don Ro's Avatar
The Harbor Freight agent (powder) warns about this.
Thanks for the info, all.
Don
Old 02-03-2017, 03:09 PM
canna change law physics
red-beard's Avatar
I use the Home Depot orange cleaner full strength. It is degreasing. I tried the "purple" stuff and left it in the cleaner for several months. Everything except stainless parts started rusting in the general area.
James
Red-beard for President, 2020
Old 02-03-2017, 03:35 PM
JJ 911SC's Avatar
From the same link @ post 6,
Old 02-03-2017, 03:41 PM
LWJ LWJ is online now
Mineral spirits. Hope it doesn't find a spark.
Old 02-03-2017, 03:59 PM
Cars & Coffee Killer
legion's Avatar
Guns? I use a gun cleaning solution from Hornady or RCBS. DO NOT USE A BRASS CLEANER. It will take the finish off.
For brass, I use 50/50 vinegar/water with a drop of Dawn, then a brass cleaner.
5 liters of VVT fury now
-Chris
Old 02-03-2017, 06:03 PM
Don Ro's Avatar
This particular gun is the AMT AutoMag II (.22 Mag) - stainless steel.
Thanks again, gents.
Don
Old 02-04-2017, 03:27 AM
