(the shotguns)
berettafan's Avatar
Best synthetic decking?
Looking to redo my wood deck with a synthetic material this spring. Does anyone have knowledge of a long lasting brand that isn't stupid expensive?
Old 03-08-2017, 10:59 AM
Charles Freeborn's Avatar
My neighbors are as I write replacing with this stuff:
https://timbertech.com
Looks good so far. I'll report back when I've seen it up close.
We're watching with interest as our back stairs / landing are scheduled for replacement this summer.
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 03-08-2017, 11:10 AM
My question would be...how bad is your current decking? Is it beyond refinishing?
There are products now that will fill in cracks and resurface to look like new, with long life.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 03-08-2017, 11:16 AM
Deschodt's Avatar
NOT TREX. No matter what. Weighs a ton and goes all wavy between support beams within a couple years... Got screwed once, and inhgerited it on another home, it's a curse..
Old 03-08-2017, 11:21 AM
(the shotguns)
berettafan's Avatar
current decking is just ugly and i'm tired of spraying constantly. I've seen paint like finishes that look good when applied but appear to be a major hassle when it's time to refinish.
Old 03-08-2017, 11:29 AM
2porscheguy's Avatar
I used this back in 2002. It still looks pretty darned good BUT it wasn't cheap back then. It might be cheaper now??
https://www.eonultra.com/
Alex
'80 911SC Targa
'06 997 C4S Coupe - SOLD
'07 997TT Coupe
Old 03-08-2017, 11:36 AM
Mine was the same and I was ready to replace with synthetic. Instead I recoated with Behr Deck-Over and couldn't be happier.
It's easy to apply (must do 2 coats) and after 4 years, mine still looks like a new surface. It fills in the cracks and screw depressions so much that it's impossible to find the screws anymore (which can be a prob. if wanting to remove a deck board)
98 Honda Prelude
22 Honda Civic SI
Old 03-08-2017, 11:39 AM
Driver
Noah930's Avatar
-1 on Trex, also. My parents have it installed for a deck by their pool. Gets LOTS of SoCal sun. It looked great at first, but many planks are now "bubbling" in a manner reminiscent of rust bubbles on painted metal. However, I also have used some scraps for small projects around the yard, and because I think the sun exposure is much less, it still looks great 10 years later.
1990 Black 964 C2 Targa
Old 03-08-2017, 01:07 PM
The laminated composites will delaminate, at least in Michigan.
If trying to save old wood, I've used Sikkens stain, the most solid color one for restoration. It has the qualities of oil and latex really seals and fills in the cracks - two coats of course. Power-wash preparation very important, and let it dry all the way.
Old 03-08-2017, 02:14 PM
Went next door and looked at the Timber Tek. It's got that plastic sort of look - from 15' you wouldn't know, but up close it's clearly a composite. It seems to be an impregnated sawdust core with laminated faces and edges. What I'm curious to see is how the fasteners work. It's got a groove cut on all edges that a clip sort of deal slides into and blind screws to the framing. Will report when they're laying the field.
1972 914/4 Race Car
Old 03-08-2017, 08:07 PM
Cajundaddy's Avatar
I redid my deck 5 years ago with this:
TimberTech Terrain Collection 47/50 in. x 5-9/25 in. x 12 ft. Rustic Elm Grooved Capped Composite Decking Board-TCGV5412RE - The Home Depot
It is T&G so all fasteners are hidden. Easy to cut and install. Looks great still with zero maintenance. I would do this again. The only downside I notice is that in the summer it gets quite hot. Not comfortable for bare feet in 100F outside temps so I always wear shoes or flops.
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 03-08-2017, 10:00 PM
Sarc's Avatar
For my projects with exterior "wood" applications, I've been using Resysta (branded Trugrain in the US) with great success. Planks are made with rice husks, salt and mineral oil and more importantly is free of ligin, which causes graying. On average its around $8/ft2.
Really nice product...
Old 03-09-2017, 10:01 AM
(the shotguns)
berettafan's Avatar
great feedback all, thank you!
Old 03-09-2017, 10:39 AM
I see you
flatbutt's Avatar
Seems to survive full sun pretty well...yes?
Old 03-09-2017, 11:38 AM
Sarc's Avatar
For sure. There's a chart floating around out there comparing it to several other products (composites, hardwoods, etc) from a fading perspective and it holds its color very well.
Old 03-09-2017, 11:47 AM
Puny Bird
Mark Henry's Avatar
Different, but I used GacoDeck because I wanted the deck to be waterproof.
Cheap because the whole deck is 3/4" G1S exterior plywood. The GacoDeck coating was easy to apply and comes as a complete kit. 50 year limited warranty.
https://gaco.com/product-details/gacodeck-kit/
Four years and no issues so far, the worst has been gum in one spot. I scrub it with soap and a broom then power wash it once a year.
https://www.youtube.com/watch?v=pTxp9iuT8tk
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 03-09-2017, 12:34 PM
I've become a fan of any deck you don't have to screw down through the planks. Either screw heads everywhere or those stupid plug things are a nope for me.
Several companies use a side clip to attach boards to the structure. Other than old school tongue and groove I'd go clip in a second
Old 03-09-2017, 01:20 PM
^^^That's how the EON decking works....clips between the planks. This means that those planks can be re-used should you decide to add an addition to your deck. It also allows access to below your deck without destroying those expensive planks.....in the event YOU ACCIDENTALLY DROP YOUR KEYS and they fall through...ask me how I know!!
Alex
'80 911SC Targa
'07 997TT Coupe
Old 03-09-2017, 01:32 PM
None are any good in my opinion. Trex being the worst from my experience. Stay with real wood and re-stain every few years as needed. Treated wood will be the least expensive and tend to shrink, warp and splinter due to the treating process and being crap wood but will last ten years or so and is inexpensive to replace. Replace bad pieces as needed. Cedar is a good stable naturally decay free wood. It will last and stay looking good for a long time. Stain if you like or let weather to silver gray. Redwood, Mahogany and Teak are a bit pricey but also very stable rot resistant and beautiful. They will last decades. Stay away from that waterproofing crap. A hint to preventing rot is to wash with salt water. Fresh water will promote rot.
Teak deck, internet photo not mine.
Old 03-09-2017, 02:07 PM
^^^ very true! especially where extreme weather is a factor.
98 Honda Prelude
22 Honda Civic SI
Old 03-09-2017, 02:24 PM
