Originally Posted by dad911 View Post
Around the house we have costco nightlights that double as flashlights, and turn on when the power fails.
And a few LED flashlights from HD, Holiday sale under $10, I won't be upset if they leak.
I threw away the maglights when LEDS got cheaper&Brighter
Maglight makes LED flashlights now. The one that I just threw away was an LED, mini maglight that ran on 2 AAs that was great for little things. Mostly, I use an LED headlight that I've got, but occasionally, something a big bigger is nice.
Old 03-20-2017, 01:22 PM
Originally Posted by red-beard View Post
Is anyone making a plug in flashlight with Lithium-rechargeable batteries? I know the lithium non-rechargeable batteries have a higher power density. But most of us wouldn't need more than an hour or two. With LED, you can get a lot of light!
I know there are lots of plug-in rechargables, but I'm not sure what their battery source is. I would think someone somewhere must be making one like that.
Old 03-20-2017, 01:24 PM
canna change law physics
red-beard's Avatar
Outlite A100, uses either a single 18650 rechargeable cell or your can use the AAA adapter.
https://www.amazon.com/Handheld-Flashlight-Rechargeable-Included-Adjustable/dp/B00VZT2WP6/ref=sr_1_2?s=instant-video&ie=UTF8&qid=1490041075&sr=8-2&keywords=rechargeable+flashlight
James
Red-beard for President, 2020
Old 03-20-2017, 01:25 PM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
I have had batteries leak in all kinds of devices. A gas powered r/c aircraft, radios, and yes flash lights too. I use a quick fix should a toxic melt down occur, I clean it off with wd-40 and steel wool, even medium grit sand paper can help out in a pinch. Now I know better.
Getting old sucks, bring back the good old days, this new stuff is for the birds..
Old 03-20-2017, 09:09 PM
red-beard's Avatar
The lithium ion batteries do not use acid for the electrolyte.
James
Old 03-21-2017, 06:03 AM
Cajundaddy's Avatar
Eneloop rechargeables instead of crappy alkaline single use batteries. These are good for up to 2100 charge cycles and I have never seen one fail and damage a light or appliance.
https://www.thebatterysupplier.com/products/newest-version-panasonic-eneloop-4rd-generation-16-pack-aa-nimh-pre-charged-rechargeable-batteries-free-battery-holder-rechargeable-2100-times.html?gclid=CLWQuaKB6NICFYlrfgodDWQIqg
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 03-21-2017, 09:26 AM
red-beard's Avatar
Eneloop are NiMH, which have a lot lower capacity than Alkaline, or Lithium rechargeable batteries. The electrolyte is NaOH, so if they rupture, they will cause corrosion.
James
Old 03-21-2017, 10:54 AM
Cajundaddy's Avatar
I think there are a lot of misunderstandings about rechargeables. In my camera gear the Eneloop lasted much longer (more shots per use) than alkaline. If they ever failed, there would be a possibility of corrosion, they just don't fail. I have seen 50 alkaline batteries fail, damaging the flashlight, strobe, or camera. In 5 years with Eneloop I have seen zero failures. Nearly all those batteries are still in service too as opposed to the one-use throwaways.
Battery Myths vs Battery Facts
Old 03-21-2017, 11:36 AM
Counterclockwise?
Put a condom on them. Make sure it's the thin type.
Rod
1986 Carrera
2001 996TT
Old 03-21-2017, 12:38 PM
Mine are way too big for that...
Old 03-21-2017, 02:41 PM
And I'd guess that you'd have to poke a hole in the end.
Old 03-21-2017, 03:15 PM
GWN7's Avatar
My dad once told me if you want a flashlight to last never leave batteries in it. He would tape them to the outside in a plastic bag where if they did leak it wasn't a problem.
Bunch of old cars
Old 03-21-2017, 04:12 PM
