Band.
All mine have numbers 8xxx sorry
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 04-22-2017, 04:22 PM
wdfifteen's Avatar
Those are only 3 or 4 pin tumblers. Easy to pick. Grind a small Allen wrench down so the short end is 1/8" long, stick it in the hole and rake it in and out against the pins while gently turning the tumbler with a small screwdriver. It should take you all of a minute to get in.
Old 04-22-2017, 05:54 PM
Platinum Member
dad911's Avatar
1/4" drill bit, 30 seconds. Replace, it's likely a standard lock like this ($5):
Prime-Line 7/8 in. Chrome Drawer and Cabinet Keyed Cam Lock-U 9943 - The Home Depot
Old 04-22-2017, 05:58 PM
Retired Member
Brian 162's Avatar
I once used 2 paper clips to pick a lock for a pool table. I inserted the straightened paper clip into the cylinder. While holding the first paper clip I inserted the other paper clip and rotated the lock cylinder. It actually worked.
I learned this from watching The Rockford Files.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 04-22-2017, 06:08 PM
The Unsettler
stomachmonkey's Avatar
Seriously those are some of the easiest locks to pick.
Paper clip to brush with and anything else to apply torque with.
Insert paperclip and you'll feel the pins push up. Withdraw slowly and you'll get a feel for them dropping.
The idea is to get them pushed up then apply torgue. As the pins drop they will get bound outside the cylinder. You can feel it happen.
You just keep torque applied to keep pins bound and go back and work th rest.
As a newb Expect you'll only bind on or two pins per brush stroke.
Even still, once you understand the concept should take you less than 5 minutes to pop your cherry.
"I want my two dollars"
"Brandon Won"
Old 04-22-2017, 06:27 PM
Thanks for the tips, been trying a bit and you can actually see them bind and not spring back down. Must be getting close.
1982 911 Targa, 3.0L ROW with Webers
Old 04-22-2017, 09:04 PM
I got it!!!! Used a paper clip and hair pin.
Annnd its empty! But had the original bill of sale inside from Oct of 1982. I cant believe how heavy it is. Receipt says it weighs 116lbs. I also picked up a ton of NOS in package and unused tools from the era. Will post pics if any one is interested.
Old 04-22-2017, 10:09 PM
pwd72s's Avatar
Congratulations! Now that it's open, should be pretty simple to install a new lock with key if you wish. Or, just never lock it?
Old 04-23-2017, 12:09 AM
I've been planning a job down at the local Wells Fargo....you in ?
Old 04-23-2017, 12:30 AM
Damn - for a second there it felt like a Geraldo story...
1972 911T/S MFI Survivor
Old 04-23-2017, 12:41 AM
A Man of Wealth and Taste
tabs's Avatar
It was a Geraldo story. There was nothing in it.
Old 04-23-2017, 04:06 AM
I have the same toolbox.
It's been serving me well for two decades.
Randy
'87 911 Targa
'17 Macan GTS
Old 04-23-2017, 05:04 AM
This thread prompted me to check the local CL for tool boxes....wow....no shortage of them there!
I already have one of those tall ones with a million drawers so I'm good for now but I found a little one that included a wide variety of tools - all made in the USA - so may pursue that one just for patriotic purposes!
Old 04-23-2017, 06:34 AM
Any ideas on the value of a 35 yo perfect made in the USA tool box?
Old 04-23-2017, 07:57 AM
I would never have expected it to weigh that much empty!
Old 04-23-2017, 08:01 AM
Control Group
Tobra's Avatar
Now that it is open, you could probably take the lock out and get keys made, though it may be more economical to just replace the lock.
Old 04-23-2017, 08:40 AM
Here's mine, well used. Different key
Great looking tool box!
Old 04-23-2017, 09:21 AM
It's pretty clear how the lock goes in, I will replace for sure if I cant track down a key. It seems as though the locks with a W on them may be from a company called Waterloo. I shot them an email so maybe it will pan out.
Old 04-23-2017, 09:24 AM
pwd72s's Avatar
No idea monetarily, but a very useful item to have and use. Great find! By the way, do post pics of the tools. Snap-on snobs would disagree, but for home use, Craftsman used to make some damned good tools. Operative word used to. Look for "forged USA"..
As far as heavy, I agree. It was a struggle to get the top chest onto my 3 chest Craftsman rollaway. I went with the ball bearing drawers with the "griplatch" feature. This allows rolling the unlocked stack without fear of drawers opening.
Old 04-23-2017, 10:26 AM
