Test your internet speeds
Speedtest.net by Ookla - The Global Broadband Speed Test
Find out what your download and upload speeds really are.
Bunch of old cars
The Stick
Been using speedtest for quite some time. They even have an app for the iPhone.
![]() Would like to have faster upload, but just can't afford it.
Richard aka "The Stick" 06 Cayenne S Titanium Edition Last edited by RKDinOKC; 05-15-2017 at 01:31 PM.. |
Old dog....new tricks..... |
Driver, not Mechanic
At work, on the guest network, using an iPad...
Download: 33.79Mbps Upload: 33.93Mbps On Chrome on a PC on Ethernet, on the office network... Download: 90.82Mbps Upload: 95.2Mbps Last edited by wildthing; 05-15-2017 at 01:39 PM.. Reason: Removing images to protect employer information. |
This may be a little overkill for gaming...
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
83 911 Production Cab #10
Over priced Rogers...
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Who is your provider and a what cost?
At home on an iPad on wifi about 30 feet away and downstairs...
![]() I will try on Friday while on Ethernet. |
This is from my desktop at work. I'm at a research university...
I have sinned!
canna change law physics
At the office - House is about twice as fast
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
30 bucks a month for 100/100 via fibre. I have 7 carriers to chose from on fibre, 4 carriers to choose from on ADSL and three carriers to chose from on 4G.
Thank you for your time, Last edited by beepbeep; 05-16-2017 at 09:16 AM.. |
There is a problem with these internet speed tests. A couple problems really which is why you are finding variability..
1. You are not measuring speed at all, you are measuring throughput capacity. The (propagation) speed of a signal over fiber is about the same as a signal over copper. Add in very necessary but comparably very slow devices to boost and route the signal along the way and it’s a wash. But you are not so concerned with speed to transfer 1 bit of data, if you want to stream a movie and that is more like a constant stream of semi trucks. Those “semi trucks” are more affected by routing slowdowns so “speed” of signal is irrelevant. 2. The “Internet” is not a single place and nothing has a direct connection. Most likely your work computer goes out through your corporate headquarters which could be in Texas even though you live in Maine and who knows where the speed rating site is. If you want to find out then download a utility called traceroute which can show you all the different routers your signal traverses. That is more significant and variable than what this speed site says. 3. People also confuse latency with throughput capacity for a “slow” link. Latency is especially critical with gaming. When you are on the phone talking you expect the other person to say “ok” every once in a while or you will stop talking. Computers are the same. You do not want that movie site to stop sending and that is often set by negotiated protocol window sizes on each side. If you have small window then any link can seem jittery so you can cover up high latency on a big movie download but not with gaming and this is more about your connection to other people rather than a speedtest site. 4. The measurement changes constantly. The route your traffic takes can change several times every second. The conditions on each of those routes and devices change constantly and other traffic will have higher priority. The traffic you send for the speed test has a completely different priority and route than the gaming you do a second later. There are lots of other things like max packet sizes, error correction, caching hosts, backbone routing levels etc. Now "speed tests" can be very accurate between themselves but have little to do with anything else you are doing over the internet. It is not like the old telephone system where you got a dedicated link for the duration of your call. Today it is all broken up into tiny packets that all go their own way. If you want deterministic speed then drag a wire from your computer to every other computer you want to connect to like the old days and you will quickly realize why things went this way. |
Band.
my cats breath smells like cat food
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Home internet
