Fleabit peanut monkey
SPICA Question 81 Spider
This is a bit windy. Sorry.
Purchased a rebuilt Thermostatic Actuator from Wes Ingram. Bought his SPICA guide as well. Car will start when cold but dies when starter stops feeding electricity to the cold start solenoid. Wes speaks of two things that a layman can look for. One is the "low" fuel pressure light. The other is the gap in the arm the TA impacts post warm up. Fuel pressure appears "ok" as light on dash blips on for way less than a second then goes out. I can't get the car warm to check the gap. Here is a little history. Car would start fine before we pulled the engine to replace clutch. However, the car would not restart unless fully warm. So, five minutes into a drive if the car was shut off, she was dead until it was stone cold again. I believe there was a lean problem then. Bring in the new actuator with it proboscis sticking out loud and proud (maybe 1/8-1/4" longer than the tired one) and I also deleted the little gasket where the TA mounts on the MI pump per Wes' guide. The plunger screw under the TA is now maybe up to 5/16" further towards lean than it was with the tired TA. I can cheat and run the car with the cold start solenoid engaged with a separate battery but I only did this for 10 seconds. I can blip the throttle doing this and it responds. Thinking at a minimum, I need to remove the EPA security cap off the screw under the TA, seat it and back off two turns per the guide. Is it possible an ignition issue could kill spark after the starter is disengaged? On CIS the Cold Start valve fogs fuel into the intake. I believe on SPICA it simply enriches what is going through the four injectors. Correct?
1981 911SC Targa |
I think you may get more traction in the 911 Tech board...
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
A long time ago when I had an Alfa and was learning how to deal with the SPICA on mine, I had an epiphany of sorts after talking to Wes about my problem. He told me each TA was a beast of its own and the spec gap was only a starting place for adjustment. Once that sunk into my head I was able to get it going to where it worked perfect.
Sorry, that's all I've got or can remember. Good luck as once running well, it really is a nice system to have on an engine. I think the answer to both your questions is Yes.
Scott '78 SC mit Sportomatic - Sold |
There is a guy there that hand builds electrical diagrams that he will e-mail to you if you pm him. Then I could track down a potential electrical culprit easier. Time to join. Even if this is as "simple" as the TA needing to be dialed in, I need to hear the info like Scott states to get in there and tweak before I call Wes. Appreciate his input. I have an Alfa pal in town that literally walked through the feed system over the phone and stressed filters, new hoses in front of the engine bay filter and a clean return line. Even if pressures are OK, I know these filters are very old. Fuel pump is noisy, too.
1981 911SC Targa Last edited by Bob Kontak; 05-17-2017 at 09:07 AM.. |
Yes, I believe his handle is papajam....it takes a few days to recieve, so hang in there
Thread Tools | |
Rate This Thread | |
