jyl jyl is online now
jyl's Avatar
Fuji XPro-1 Problem
Troubleshooting my daughter's Fuji XPro-1 camera. When switched "on", LCD turns on with gray screen, otherwise wholly unresponsive. Removing/replacing battery, trying w/ and w/out memory card, lens makes no difference. Tested battery, reads 7.1 v, spec is 7.5 v. You think this voltage is low enough that the battery is the culprit? Should I order a new battery?
Old 05-21-2017, 10:16 AM
That'd sure be the place I'd start.
Isn't it a rechargeable battery?
Scott
'78 SC mit Sportomatic - Sold
Old 05-21-2017, 10:23 AM
You might also try this forum for an answer:
https://www.fujixspot.com/
The fella that runs it runs the Sony forum I'm on and it's a pretty nice group. They'd probably know the answer.
Scott
Old 05-21-2017, 11:51 AM
dan79brooklyn's Avatar
I had problems with my fujifilm x100. The aperture blades were stuck open. It was a design defect and they covered the repair. I suggest you check the online forums/google.
Old 05-22-2017, 01:17 AM
