Team California
Anything to worry about?
The alternate title for this could be, "I'm an idiot, volume 63."
![]() I dropped a small rubber plug into the oil pan of the engine I just assembled. I was putting it into the hole where the dipstick enters the pan, (to keep dirt out), and it was too small and fell in. ![]() It's in the pan and would not be able to get past the screen on the sump to get sucked into the veins of the engine while running. The worst thing I can envision is it getting stuck in the screen, due to the small hood over it, and blocking a very small percentage of oil intake to sump. Hopefully, it will come out w an oil change in the future. I can't get it out by removing the drain plug and hitting the pan w a rubber mallet, I tried. Of course, I could remove the oil pan and retrieve it but that is no small job because it's glued on w very high strength chemical adhesive and it would be several hours of removing the old sealant before reinstalling. Trust me on this. Is there any reason to worry about it in there? Give me your expert opinions. Here are some pics, including a twin to the offending item: It went in this hole:
Denis |
Any chance of fishing it out through the drain plug? Another crazy thought...my shop vac has a small diameter blower nozzle. I've plugged tubing onto that nozzle for more size reduction, can really vacuum in spaces I couldn't reach otherwise. So, maybe a piece of small dia. tubing hooked to a shop vac could pick it up. My 6.5 horsepower shop vac really sucks...I call it Monica. A small tube with it's sucking force would pick up the piece if you got anywhere close..
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) Last edited by pwd72s; 05-13-2017 at 12:04 AM.. |
The Unsettler
I would try turning the motor upside down and shaking it kinda like when you drop a pick inside a guitar.
I assume the motor has clean oil in it? If not it will need some at some point anyway. Try draining it and see if it floats out.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Can you peek in there and see it? Maybe you can pluck it out with a pair of tweezers like a wood splinter.
I honestly cannot see it causing any harm. Of course, the hour or so you would spend pulling the pan, will be be better than a lifetime of worrying about the what if's.
No left turn un stoned |
unsafe at any speed
Try adding some diesel or kerosene to the crankcase... positioning the engine so the drain plug is at the lowest point then pull the drain plug. perhaps it will drain out with the fluid.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
weekend wOrrier
I would try suction idea through dipstick hole. I like the kerosene idea too.
Another quick ( probably unsuccessful) idea to avoid removing pan. Assuming no oil in engine. Tilt engine at strong angle with drain hole at lowest point. Blast highest possible pressure compressed air into dipstick hole where plug fell. This just might be enough to get the piece to rattle/ move towards drain hole, at least to a point where you cold retrieve it. Perhaps even mount vacuum to oil plug drain hole with a good seal (but you'd need a clean vacuum bin to see the piece to know if it got sucked out) Spend no more than 60 seconds or so on above idea
Registered ConfUser
Go ride motorcycles around Europe
for a week. Come back, open a cold beer, spend 3 hours removing the pan, collect the offending plug, reinstall pan and never worry about it again.
Mike “I wouldn’t want to live under the conditions a person could get used to”. -My paternal grandmother having immigrated to America shortly before WWll. |
How about shoving a camera in the drain hole? The one I have has a claw on the end to grab things. Might be able to see it and retrieve it that way.
Von http://vonsmog.com 73' 911T Coupe, 76' 911S Targa 73'& 80' Mercedes Unimog DoKa 59' Austin Healey 100-6 |
Functionista
I don't think it's a big deal but a bore scope with sticky tape reverse wrapped toward the tip could also get it out.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Fast Acting, Long Lasting
I doubt that vacuum plug will cause a problem unless, through some strange injector sleeve / seal failure you end up with a gallon of diesel in the crankcase. That would make that rubber plug turn into goo which could compromise the lube oil pump and pressure control valve..
The worst I could imagine is the lube oil pressure control valve sticking open, causing lube oil pressure to go near zero, HPOS would get starved for oil to run the injectors, IDM would stop firing the injectors once control pressure dropped below 500 psi, engine would shut down in about 2 minutes after losing lube pressure, and long before any cam and lifter damage was done. ...but I doubt that would happen. That vacuum plug will likely just live a quiet and boring life down there in the pan.
Eighteen ways to burn fuel. |
Denis, I would be concerned with the rubber plug getting chewed up by the crank and getting turned into lots of little pieces that could get past the pick up screen.
Hate to say it, but if it were me, I would pull the pan and get it out. Better safe then sorry.
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
I can send you a few really cool surgical instruments that you might be able to grab it with. Let me know if that's an option.
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
Something like this...
I second the camera option. I know me. I would obsesse over it.
Team California
Thanks for all the responses. There is probably no getting it out, unfortunately. The drain is dead center in the bottom of the flat part of the bottom of the pan, not on an edge or in a corner where you could tilt the engine to make it roll that way. I'll try the shop vac and compressed air but really doubt it will come out. The drain is relatively small w threads going fairly deep upwards. It may come out w a future oil change, maybe.
It cannot get "chewed up by the crank", the entire oil pan interior is covered w a huge sheet metal baffle w some holes in it. Think a swimming pool cover w a few holes. It is in bottom of pan already, (engine is still dry). I don't have a horoscope camera. It would be a neat thing to have but doubt I'd find one today. All of the cheap ones I found when looking last time worked w PC/Android and I don't have any of those. I don't think I even have enough of special glue/sealant that International uses to seal the pan left. I got one big tube w the lower gasket set for motor. Time to clean the shop vac really well and play w that. I'm also going to see if the other plug sinks or floats in oil. If it sinks, I'm less worried. Thanks again.
Denis |
Remove the drain plug and blow air in dipstick hole?
Team California
As for tipping and shaking, (besides the fact that it would put the rubber plug somewhere over than where you want it), you would need to borrow several mature apes or gorillas from the zoo, bring them home and feed them pcp while playing a continuous loop of modern country music to get them pissed off enough to tip and shake a 1k lb. motor while somehow not touching the other vehicles and machinery in the shop. Not practical. As my dad used to say, "you're using a machine gun to kill a mosquito".
Denis |
Team California
Otherwise, it would be manana/adios.
Denis |
![]() ![]() Maybe you could hold onto the dipstick holder with a long piece of vacuum line stuffed thru the dipstick hole, and take the big nut loose that attaches the holder in the side of the pan to open up a bigger hole to go fishing in. I know, its very risky, losing the dipstick holder into the bottom of the pan, and the windage baffle will be in the way, but it's an idea. just make sure the vacuum line is large enough diameter to stay in the hole with some friction. I've done this on 7.3's to replace the o-ring between the holder and the pan with the engine in the truck.
Eighteen ways to burn fuel. Last edited by yetibone; 05-13-2017 at 03:43 PM.. |
