LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
Uh, dealer says my 10mm wheel spacers are causing my TPMS malfunction!
Old 07-19-2017, 10:52 AM
So if you remove them, the error codes stop?
Neil
'73 911S targa
Old 07-19-2017, 12:34 PM
I really can't see spacers causing this problem. Spacers have been on the car since I got it, or for 6000 miles with no problems whatsoever. These are Turner Motorsport BMW spacers so there should not be any issues.
Old 07-19-2017, 12:56 PM
Banned
Spacers have nothing to do with it your dealer is an idiot. Disconnect the crap and monitor the pressure yourself. Any indie can do it for you. I've done it on the P car myself but I have the SW and the bypass instructions.
Old 07-19-2017, 12:59 PM
The wife's car had a TPMS last year - don't remember the exact cause. I took it to the dealer (stealer?) who wanted $100 just to look at the car. The sensors were an exorbitant price. Took it to an indi shop that wanted $114/wheel to fix it. Then I decided to take it to Discount Tire where the tires came from. They fixed it for free in about an hour.
Marv Evans
'69 911E
Old 07-19-2017, 01:46 PM
I just bought a Bentley manual for my girlfriend's 328i. I cracked it open during lunch, and noticed that TPMS, and traction control, abs, etc all connect via a CAN bus to a dme type unit. I wonder if it makes sense to use a BMW specific PC scanner to troubleshoot and test the TPMS brain? If not, then I wonder if it can be sent in to a specialist for a bench test.
Old 07-19-2017, 07:25 PM
Is there a BMW program similar to the pro Durametric for Porsche? You could disable the sensor if you have programming enabled on your software. Of course, it's better to fix the problem.
Old 07-19-2017, 07:27 PM
I'm glad I don't have the BMW anymore, was starting to get to know the people at the stealership on a first name basis.
Old 07-19-2017, 07:48 PM
Banned
I disabled mine with pro durametric. I can't imagine there isn't something similar for BMW and I know my indie has the BMW SW. In Porsche's case you just tell the car the option was never installed. OP may want to check the BMW boards.
Old 07-20-2017, 04:03 AM
Still Doin Time
asphaltgambler's Avatar
If the dealer is an actual BMW ( as in new) they have the factory scan tool. Doesn't mean the tech is using it properly............
Old 07-20-2017, 07:26 AM
I kinda suspect the dealers scan tool is suspect.
It showed bad wheel sensor, they replaced it, problem still there, now they want to replace another wheel sensor!
I get accurate tire pressure readings, the TPMS system just resets itself every 30 minutes/miles
Old 07-20-2017, 08:06 AM
Still Doin Time
I would tell them - when you know exactly what the problem is and then fix it, call me. Until then you've already spent your money and time, the issue remains.
Old 07-20-2017, 08:54 AM
Update..
Took car to Classic BMW. Plano Tx
Unbelievable dealership!
5 star service for sure. I got a 320i loner which was nice. The TPMS malfunction issue was a combination of the EDC module and a software upgrade. Car now good as new !
Classic BMW impressed me to make them my dealer, yes, they are 5 and 1/2 hours away but I was impressed!
Old 07-30-2017, 06:22 PM
I really love this car. With 6000 miles on it the car sits a lot ! Don't know if that has anything to do with it. Never heard of a wheel sensor going out this quick, but , it Happens. Lots of posts about bad wheel sensor batteries out there.
Wheel sensors batteries are a notorious problem on all cars. To the best of my knowledge the sensors are not proprietary so a few manufacturers supply all brands. First if replacing one sensor replace them all. Second I have found buying the sensors from Ebay at $15.00 each to be just as reliable as dealer supplied part at $60.00.
I have replaced the sensors in both my Jeep and Nissan with the Ebay parts. No issues Jeep two years, Nissan one so far
Old 07-31-2017, 03:16 AM
Rinty's Avatar
I had read on the Rennlist that some of the Porsche owners were doing this. I have TPMS on an Audi TT and it hasn't malfunctioned yet, but it did when the first owner still had it.
Old 07-31-2017, 09:05 AM
